Intake backfire
Old Jun 26, 2004 | 12:40 AM
ZMAN Z28's Avatar
Intake backfire
I just moved back to South Dakota, and went to the track. To make a long story shorter, I left the line at around 3500 rpm's with the nitrous armed. I usually spin the nittos, but this time the car totally hooked, and as a result it bogged. As it bogged, I heard a loud bang, and the car died about 100 feet. Give or take a few feet. It mushroomed my airfilter, destroyed my ILE elbow and hurt my MAF. We pushed the car back to the pits, and I tried to see if the car would start, it would not, so I ducktaped all the rubber back together, and it still would not start. Got a bit depressed and went and got a soda and a cheesburger. Called a great friend of mine who told me to unplug the MAF. Walla the car fired right up. OOPS on my part. So now do you think this is a more stable plan to run my nitrous. Switch to a plate? I have the Nitrous Express nozzle kit right now. Oh yeah, the car ran just fine on the way home 40 miles. Good oil pressure, and no knocking or pinging. I m pretty sure I didn't hurt the motor or bend a valve or anything like that. Any comments appreciated good or bad.
ZMAN Z28
Old Jun 26, 2004 | 12:48 AM
LSUxBlake's Avatar
Man, that sucks. Try searching for backfire info. It doesnt happen too often, but I have read a couple threads about it. One question, are you running a WOT switch? It does't sound like it from how you described leaving the line while spraying.
Old Jun 26, 2004 | 12:59 AM
ZMAN Z28's Avatar
Yes I was running a WOT switch. I did take off the fuel pressure safety switch, because it went faulty and would not let the nitrous activate untill I bypassed it. And I also had plenty of fuel pressure. It sure did scare me petty bad when it went bang and the car slowed to a halt. I at first thought the rear end blew up. Which it didn't. I was relieved about that atleast
ZMAN Z28
Old Jun 26, 2004 | 08:43 AM
LPEdave's Avatar
You need a window switch, that's what they're for - keeping you from spraying at too low, and too high of an RPM.
Dave
Old Jun 26, 2004 | 07:21 PM
ZMAN Z28's Avatar
Thanks for the advice guys. A window switch sounds like a great idea. I am looking at the MSD digital window switch part number 8969.
Are these pretty easy to hook up? I am not very good at wiring. I can do it and don't like doing it, but can do. I am running the crane hi-6. Will there be a lot of splicing?
Looks like I am going to need a new WOT switch, as when I looked at the car better today, mine was only half there from the backfire.
Thanks
ZMAN Z28
Old Jun 26, 2004 | 09:56 PM
MEAN_SBC's Avatar
Nah, it'll be a piece of cake to hook up.... Pretty much a 4 wire install.... I'm pretty sure you can do it no prob...
power wire, ground wire, tach wire, and activation wire.......... Dat's about it..
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
Chet1185
May 10, 2015 09:24 AM
Noenav
Apr 30, 2015 01:06 PM
Drtryder
Apr 22, 2015 04:17 PM
F(ast)-body
Feb 26, 2003 09:05 AM
