msd window switch all messed up?
Old Jun 22, 2004 | 06:55 PM
1mostlystockz28's Avatar
i have a 2001 camaro ss and i put my nitrous stuff from my 94 Z28
and i used the msd window switch and everything, but now when i try to spray i will come on when its supposed to but then it will shut right off. so im wondering if it aint my window switch that is all messed up or what but any ideas will be appreciated.
Thanks Jason
Old Jun 22, 2004 | 10:34 PM
scottland174's Avatar
i believe the LS1 gives a tach signal like a 4 cylinder. that might be a problem
Old Jun 23, 2004 | 02:57 PM
from what i understand you have to cut both the blue and the red wires. a buudy of mine has a 02 ws6 with both the red and blue wires cut and he runs mid 11's all day long so i think its my window switch all messed up any other ideas would be appreciated
Thanks Jason
Old Jun 23, 2004 | 04:44 PM
LSUxBlake's Avatar
Is the fuse blowing once the window switch is activated? Or is it just shutting off? Mine was doing the same thing, but it would blow my fuse everytime. It turned out I had a bad window switch.
Old Jun 24, 2004 | 10:16 AM
no its not blowing fuses and that is not making any sense. you would think that if it was bad that it would blow fuses?
Thanks Jason
Old Jun 24, 2004 | 01:31 PM
LSUxBlake's Avatar
No, not necessarily. If it is activating for a second, then that means the switch turns on but thinks it has to turn off right after. What pills do you have in it right now? Maybe its a bad pill? Try a different "Off RPM" pill
Old Jun 24, 2004 | 01:39 PM
there was a 6000 off pill then i put a 6200 off pill in and it still does it.
Thanks Jason
Old Jun 24, 2004 | 01:40 PM
LSUxBlake's Avatar
Assuming it is wired correctly, I can't think of anything else besides a bad window switch.
Old Jun 24, 2004 | 03:04 PM
well i tried a new window switch and new realys but it still dont work im so frustrated right now its not even funny. but any more ideas are appreciated.
Thanks Jason
Old Jun 25, 2004 | 01:43 PM
mikey9495's Avatar
1mostlystockz28,
What MSD part number are you using?
If you want a window switch guaranteed to work with your LS1 in 4-cylinder mode, feel free to write me at mike@bmnracetech.com
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
