Relocating brackets?
Old Jun 18, 2004 | 04:07 PM
Snowmann's Avatar
I have subframe connectors and rear LCA (BMR flavor) and I am anticipating some major traction problems( ordered a 3200 vigalante yesterday), what about these relocating brackets for the rear LCA, do they work well and how do they work and what do they do exactly, will they work with my existing LCA Thanks a ton for your help, its greatly appreciated
Old Jun 19, 2004 | 02:15 AM
Xride's Avatar
they lower the something angle (its late, I dont know why I am even replying )
they work well, and they will work with your existing LCA's
Old Jun 20, 2004 | 12:59 PM
Bud M's Avatar
They work by putting the rear lca mount lower than the front so when you accelerate and the rear axle tries to push forward, it pushes downward and gives you more traction.
Old Jun 20, 2004 | 04:29 PM
Snowmann's Avatar
Thanks, that is exactly what kind of info I was looking for. Bud M, looks like you have them in your sig, did you notice anything?
Old Jun 20, 2004 | 07:35 PM
Bud M's Avatar
No, not really. I could still spin em really easy with stock size tires. On a higher hp car with bigger, stickier tires it may be mopre beneficial.
But I'm considering lowering springs before too long and I think they are a necessity for a lowered car.
Old Jun 21, 2004 | 10:23 AM
mongse_1's Avatar
With the converter, I'd look into getting some stickier tires. The best suspension in the world does no good, if you got no bite.
The relocation brackets lower the rear mounting hole on the axle. By doing this, it prevents the LCA from becoming parallel w/ the ground under launch, which will cause wheelhop.
Old Jun 21, 2004 | 02:13 PM
Red96Lt1's Avatar
If you get a torque arm it should help you out some on straight line traction.
Old Jun 21, 2004 | 02:25 PM
MrDude_1's Avatar
http://josh.swoca.net/board/mrdude/LCAangle.gif
Old Jun 21, 2004 | 04:30 PM
Snowmann's Avatar
Thumbs up
Mr.Dude 1 thats pretty cool, everybody should check that out
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
War Engine
Sep 18, 2015 07:28 PM
realistyc
Jul 28, 2015 07:32 PM
Boss002
Jul 24, 2015 10:47 AM
