Another "How are these times?" thread
Old Jun 17, 2004 | 09:45 PM
a327vette's Avatar
Smile Another "How are these times?" thread
I took my camaro to Rockingham last week, just curious if these are about on par with what it should be....I was hoping for better.
Here's the mods
1994 Z stock engine w/150,000mi., Spec III clutch, 3.42 gears with worn out posi in the 7.5, sportline eibach springs, Weld Prostars with 26x10.50 ET Streets, ATI P600b@8psi, some brand of shorty headers, holley 52mm TB, 255lph fp, flowmaster muffler only, stock I-pipe, subframe connectors
I dont have the slips here, but what I remember was:
60' 1.97
1/8 8.18
1/4 12.54@112mph
Before the blower, the car ran 13.7@102mph
I was hoping for lower 12s, but with no tuning except for me with a tech I, I guess I cant be picky
Does this sound about normal for my mods? I am soon adding a 9" with around 4.10 gears, Jet hot long tubes and true dual 3" exhaust, should this get me low 12's-high 11's?
Thanks
Stevie
Old Jun 18, 2004 | 12:03 AM
david97gsxr's Avatar
8 psi on the stock engine? with 150,000 miles??? you got a big pair........
Old Jun 18, 2004 | 02:31 AM
AL SS590 M6's Avatar
I was thinking it, you said it.
Old Jun 18, 2004 | 08:17 AM
a327vette's Avatar
oh, that is a stock motor that has had 125 shot sprayed on it regular from 75,000 until about 5,000 ago when I put the blower on
I give it every opportunity to die if it wants to, but it loves me and wants to stick around
I am considering giving it a small shot (like 75 or so) with the blower to see what happens before I swap in the 396
Old Jun 18, 2004 | 09:21 AM
T/A lt1's Avatar
I think those times are good for just the supercharger for power and those 60' times. I wouldn't go lower than 3.73's if you are staying with a blower or n2o. You could go low low 12's if it can stick and 60'. A little practice driving could help until you break the rear. I ran 10.80's@126mph on a stock bottomend just a cam and ported LT1 heads(stock valves) + 150hp N2o.
Old Jun 18, 2004 | 11:40 AM
camaro81's Avatar
were you at rockingham on the 12th? i was there also
if you want to get that thing tuned, you should check out www.Carolinaautomasters.com Jeff Creech is the man when it comes to LT1's, i'm sure he could get some more ET outta that motor for you
Old Jun 18, 2004 | 11:55 AM
a327vette's Avatar
I was there on the 5th, I guess it has been 2 weeks. I have raced you though, during the super chevy show several years ago, you had the white beast of an 81 camaro...I believe I put you out
Old Jun 19, 2004 | 01:43 AM
camaro81's Avatar
haha
i dont have that car anymore, it was way to unreliable, i had to go to EFI cause at least now if the cars running inconsistant, i can tell whats causing it
Old Jun 19, 2004 | 05:21 AM
Raptor1's Avatar
Originally posted by a327vette
... you had the white beast of an 81 camaro...I believe I put you out
Must have been pure luck
armedtrigger
Feb 24, 2015 08:30 PM
marineengineer
Feb 9, 2015 03:59 AM
cyteone
Feb 7, 2015 06:04 PM
squarehead
Jan 15, 2015 07:02 PM
