Help me complete my nitrous list>>>
Old Jun 14, 2004 | 08:13 PM
F(ast)-body's Avatar
time to spray.....here's my list of things to buy. Anything I'm missing??
1) TNT wet kit 150-300 HP
2) window switch
3) purge
4) remote bottle opener
5) ??
6)???
Old Jun 14, 2004 | 08:40 PM
12Second3rdgen's Avatar
*********Fuel Pressure Safety Switch********
Bottle warmer and/or blanket
Blowdown Tube assuming you are running a 3rd or 4thgen
Old Jun 14, 2004 | 09:05 PM
bottle warmer worth the $$$$??
....anything else I'm missing??
Old Jun 14, 2004 | 09:25 PM
Bottle warmer is nice if it gets cold where you race or if you plan on racing during the cold months (if you have them where you live). Bottle pressure directly relates to how much nitrous your engine sees, so its nice to be able to control it when its cold outside and your bottle pressure is low .
Old Jun 14, 2004 | 11:58 PM
OBE1 95Z28's Avatar
I believe a bottle warmer is a must...if your bottle isn't up to temperature your pressure will be low, causing you to run rich.
Old Jun 15, 2004 | 12:27 AM
'68LT1camaro's Avatar
Instead of that window switch, look at the Jacobbs Nitrous Mastermind. It's a window switch, rev limiter, progressive controller, and ignition retard all in one box, for $225 from Summit Racing. I'm shocked that more street nitrous guys don't use this nitrous computer. The Nitrous Mastermind requires the use of an aftermarket ignition box, like the MSD 6A. Remember that the Nitrous Mastermind has a rev limiter, so if you pick one up you can buy an ignition box without a rev limiter to save some cash. The Nitrous Mastermind does require the use of one extra nitrous solenoid, run inline with the main nitrous solenoid to act as a safety.
Old Jun 15, 2004 | 08:16 AM
HeavyChevySS's Avatar
I have a Jacobs Nitrous Mastermind I purchased used a couple months ago for my up and coming cheater kit install. But I think I am NOT going to use it and will be selling it.
Let me know if you want it.
PM me or email
Old Jun 15, 2004 | 05:09 PM
I'd definitely consider the Nitrous Mastermind but I never intended on messing with my ignition so that's got me kinda negative on using it....
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
force10
May 11, 2015 10:51 AM
alphaauto
Feb 5, 2015 05:25 PM
bandit383lt4
Dec 21, 2014 09:12 PM
