long rubber piece for slp cai??
Old Sep 22, 2002 | 06:43 PM
fiz's Avatar
fiz
Where does the long rubber tube thing go? I installed my SLP CAI the other day and didn't use it cause I didnt know where to put it, and the directions i had didn't mention it
Old Sep 22, 2002 | 07:27 PM
Capn Pete's Avatar
Question
Are you talking about when installing an aftermarket lid, and what to do with the small hose that attaches to the factory airbox?? If that's what you're talking about, when I installed my "Direct-Flo" lid, it cam with a small filter that goes into the end of that tube, and you just have to tie it off somewhere so it doesn't flop around. That tube (I think??) goes to the air pump.
If that's not at all what you're talking about?? Sorry!!
Old Sep 22, 2002 | 09:26 PM
fiz's Avatar
fiz
nah not a lid, a cold air induction...
Old Sep 22, 2002 | 11:07 PM
PSU 98's Avatar
The long rubber piece seals off the open slot in the front of the airbox, where the air came in before the CAI install. If it's not sealed you won't get optimal results from the CAI.
Old Sep 23, 2002 | 02:07 AM
fiz's Avatar
fiz
Damn, I don't really understand what you're talking about, maybe you can send a picture or some one else can explain it better?
thanks.
Old Sep 23, 2002 | 02:04 PM
PSU 98's Avatar
Check my webpage in the sig. The third pic from the bottom is an underhood shot and you can see the airbox with the rubber strip attached in front. It slips over a lip there and closes off the opening to the airbox. I don't know how else to explain it, but I'll try
Old Sep 23, 2002 | 05:49 PM
NickFL's Avatar
CAI questions...
How do you like it? How much SOTP increase did it give you? Does anyone have any Dyno results from the SLP CAI? How about the sound? Any information would be appreciated. I am planning on doing the CAI and the lid very soon.
Old Sep 23, 2002 | 07:34 PM
PSU 98's Avatar
The lid and CAI are "must do" mods. You won't be disappointed.
Old Sep 24, 2002 | 02:10 AM
fiz's Avatar
fiz
well, i didn't notice any CAI gains...
I dont have hte rubber piece on though
I think it's on correcty.. I cut out the thin air shield thing liek it said, and slid down the metal CAI piece, then screwed it down to the base of my car, the opening is right under the air filter, then it goes all the way down adjacent the radiator, and hangs down toward the ground.... i don't see how this improves air flow.. don't really get how it works.
Old Sep 24, 2002 | 01:09 PM
psychocabbage's Avatar
the theory is that it makes the air more accessible than it was from stock.. also, air traveling towards the front of the car at say 70MPH is forced into the opening... thus raming the air in.
not too bad.
But I would rather have a full ramair like the FTRA or the plastic version.
Cam's maro
Jan 30, 2015 09:21 PM
97 RedSS
Jun 10, 2003 07:58 PM
Thebeast431
Aug 25, 2002 05:06 PM
Z28STYLE23
Aug 17, 2002 07:40 PM
Thebeast431
Aug 8, 2002 01:39 PM
