How to get the flywheel off!?
Old Jun 8, 2004 | 06:57 PM
camz383's Avatar
I am trying to get the flywheel off, but the thing keeps wating to turn, how does everyone get the thing off? Stick something in there?
Old Jun 8, 2004 | 08:47 PM
phil94-T/A's Avatar
I used an impact gun to remove the flywheel. If you don't have access to one, you can have someone hold the crankbolt at the front of the engine with a rachet. As your buddy holds the crank bolt that should allow you to loosen the flywheel bolts.
Hope that helps.
PHIL
Old Jun 8, 2004 | 10:44 PM
y5e06's Avatar
extensions
I did this on sunday. If the car is up on jackstands i.e. close to the ground you can use a few long ratchet extensions with a socket on the end. place the extensions perpendicular to the floor and have the socket catch one of the ears (where the PP bolts into) of the flywheel near the 9 o'clock position. That should hold it plenty when trying to remove the flywheel bolts. I had to use two 10" extensions and a deep well socket. I also had to use a breaker bar to get enough leverage to loosen the flywheel bolts.
Old Jun 9, 2004 | 12:21 PM
kgkern01's Avatar
Impact guns are nice!
Old Jun 9, 2004 | 01:56 PM
camz383's Avatar
I said forget the crazy stuff and went to borrow my dads impact, came off like gravy haha
Old Jun 9, 2004 | 05:22 PM
PatriotTA's Avatar
One of the best tools I've ever bought.
Formula Steve
Sep 19, 2023 08:31 AM
Ericksd
Jan 20, 2016 06:07 PM
karpetcm
Sep 29, 2015 10:08 AM
Jake Bialke
Sep 24, 2015 11:31 AM
Bxlt1
Sep 17, 2015 08:31 AM
