Where to put the Cutout..
Old May 28, 2004 | 01:38 PM
BigRedZ28's Avatar
Ok, my friend wants to install a cut out on his Formula. He's got a stock exhaust system and wants to know where to put it for best gains/sound or whatever. Also how involved is the install? do you NEED to weld? Thanks for any info.
Old May 28, 2004 | 02:00 PM
teke184's Avatar
you probably will need to weld since stock pipe is 2.75" and the cutout is 3"
put it in the pocket just before the axle...it fits perfect
Old May 28, 2004 | 02:24 PM
MysticTeal 95 V6's Avatar
That's the same spot I had mine installed. If you position it in that pocket correctly, you can access it by laying down beside the passenger side rear tire easily
Old May 29, 2004 | 10:34 AM
BigRedZ28's Avatar
Thank you
Old May 29, 2004 | 03:27 PM
Kryckter's Avatar
Another vote for putting it right before the pipe bends to go over the axle. I just had a custom exhaust shop make me one real quick. It is real nice access if you lay on the ground by the passenger side back tire.
Old May 30, 2004 | 05:54 PM
80TA's Avatar
And if you don't want to lay down there just buy an electric cutout.I like my dmh.Had a qtp..like my dmh better.
Old May 30, 2004 | 08:33 PM
Black01_Z's Avatar
weld one in right after the y pipe goes from 2 to 1 1 pipe.
Old May 30, 2004 | 09:35 PM
Red96Lt1's Avatar
Or just buy 2!
Heathen1
Jan 2, 2016 04:27 PM
grgguy
17
Feb 23, 2015 07:57 PM
WildRidez
Feb 23, 2015 07:24 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
NewsBot
Dec 28, 2014 06:20 PM
