Shocks and Struts, the difference?
Old May 26, 2004 | 11:32 PM
Poik's Avatar
Question Shocks and Struts, the difference?
Title says it.. What is the difference between shocks and struts? What does my 1997 Z28 have in the front and rear?
Old May 27, 2004 | 12:47 AM
99blackSS's Avatar
I am not sure on the difference. I know the fronts are struts at least because of "strut tower" bars.
Old May 27, 2004 | 01:41 AM
Eddie95Z28's Avatar
I am pretty sure 4th gen's are coil over shocks in the front... 3rd gens are struts. Struts are just shocks/springs in one I think.
Old May 27, 2004 | 05:29 AM
Mtrhds94Z's Avatar
4th gen are not struts..
See Injuneer Fred's [the last post in this thread] post here:
http://web.camaross.com/forums/showt...ghlight=struts
Old May 27, 2004 | 08:06 AM
Terran2k's Avatar
4th gens aren't struts upfront, and STB = shock tower brace, check BMR website
http://www.bmrfabrication.com/F-bodyChassis.htm
almost all the way down.
Old May 27, 2004 | 09:55 AM
Red96Lt1's Avatar
Shocks merely dampen the spring rate. Struts do the same but are also a structural part of the suspension. The upper A arm is usually stationary in a strut setup. Strut type suspension is cheaper to make and doesn't give as good of a ride. Which is why mustangs use them. (or at least use to)
Old May 27, 2004 | 02:15 PM
99blackSS's Avatar
http://thunderracing.com/catalog/?ac...&vid=3&pcid=40
The BMR website would have to be the right one though.
Old May 27, 2004 | 05:05 PM
Mtrhds94Z's Avatar
it's a 'shock tower brace' not a 'strut tower brace' on a 4th gen..
Old May 27, 2004 | 05:59 PM
99blackSS's Avatar
Thanks Mr. Obvious.
Old May 27, 2004 | 11:22 PM
shoebox's Avatar
Originally posted by 99blackSS
Thanks Mr. Obvious.
Apparently not too obvious by your first post.
Old May 28, 2004 | 12:28 AM
99blackSS's Avatar
By the time he responded it had been pointed out three times already.
I am glad everyone feels the need to continue to point out that I was wrong, sorry for trying to help.
Old May 28, 2004 | 06:40 AM
Rob:
Just curious..... what does GM call the suspension components in the 4th Gen, the shocks in particular?
I had this similar discussion on the "Suspension...." forum, and the conclusions by one individual was that "...I will keep calling them struts because that's what GM calls them."
Old May 28, 2004 | 12:20 PM
Mtrhds94Z's Avatar
If you read the posts, MY POST was the first, and only one, that didn't say 'I think they are this, or that' but had a link showing the actual differences [thank's Fred!] which SHOULD clear it up.. So one of the '3 posts already' was mine anyway..
Then you continue with your 2nd post [Thunder link] with what appeared to be an attempt to dispute it..
So I responded reaffirming that they are shocks..
Now I am responding THIS time to your 'cutting remark' [Mr. Obvious..] Which was very unneccessary.. [talk about useless unneeded posts!..]
I am not in the habit of making 'frivolous' posts..
It's just that this seems to get debated here on a weekly basis..
Fred and Rob, all references to shocks for 4th gen in both the parts CD and the 94 factory service manual for both F87 and F67 options are:
Absorber, Frt Shk
I see no reference at all to 'strut'..
Charlie
Old May 28, 2004 | 11:59 PM
shoebox's Avatar
You poked at Charlie and I poked back a little. Sorry, I was j/k around ...as I hoped you were. Nothing to get excited over.
Fred, Charlie is right. I have never seen any reference to strut (only shock) in the parts book and in the factory service manual. It does not help the confusion when half of the vendors call them struts, too. People like you, Charlie and I are detail oriented, so it bothers us.
mrwz28
Jul 8, 2015 09:11 PM
SergheiS
Jul 5, 2015 03:27 AM
timmy39120
May 2, 2015 05:12 PM
Magenta_Hearts
Mar 22, 2015 02:44 PM
DropTop91
22
Aug 8, 2002 10:53 AM
