horrible gas pedal response, why?
Old May 26, 2004 | 10:03 PM
ed's85irocz28's Avatar
Angry horrible gas pedal response, why?
If I'm in drive and floor the gas pedal, the car will only slowly but steadily accelerate for sometimes up to 5-6 seconds, and then all of a sudden it picks up like I gave it a shot of nos and it takes off.
I know the car did sit for maybe about 2 years, and I dont know how long it might have sat before that.
Any idea's what the problem might be, or what I should replace?
Please help, this really sucks.
Thanks
Old May 26, 2004 | 10:11 PM
95_LT1_6SPD's Avatar
If it has sat for that long, try basic things like Plugs and wires, cleaning the tb, changing the fuel filter etc.
Old May 27, 2004 | 12:12 PM
My Red 93Z-28's Avatar
what do you do when you clean the TB??
Old May 27, 2004 | 12:42 PM
Schearer225's Avatar
To clean your TB, first unbolt it carefully and the throttle cables. watch out for the small amount of coolant that will leak out of the coolant lines passing through the TB, now is a good time to do a TB bypass . Then just clean the TB with TB cleanner that you can get at any automotive store, and spray it on and let it eat up that gunk. For the caked on stubbern stuff i just used a toothbrush or soft type bristle brush. Thats all i did and mine was as clean as a whistle . Hope that helps
Old May 27, 2004 | 12:57 PM
clean the blades or what?
Old May 27, 2004 | 01:29 PM
teke184's Avatar
the blades and the bores.
and make sure you reoil the butterflies...i cleaned mine once and didn't reoil it, and they would hang up and basically stay open even when not on the pedel.
Old May 27, 2004 | 04:15 PM
Today I went to napa and bought a bottle of marvel mystery oil, injector care plus, and valve & lifter cleaner. I hope this helps. Is there anything else I should get?
I hope it dosnt OD if I add all this juice at once
What does TB stand for?
Old May 27, 2004 | 08:20 PM
smoknta's Avatar
TB= Throttle Body
Old May 27, 2004 | 09:51 PM
Another thing it could be is bad gas, how many times have you filled up since you started driving after it sat?
Old May 28, 2004 | 01:52 PM
Ive drove it just about everyday for about a month now, so its been through a few tanks. The old gas could have gummed some things up.
Today I had 3/4 full tank of gas, and i added 36 ounces of 100% isopropyl alcohol, 10 ounces of marvel mystery oil, 16 ounces of injector cleaner, and to the oil i added 12 ounces of valve&lifter cleaner with a little marvel mystery oil.
I think that should clean most of it up.
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
zajones
Jul 30, 2015 02:18 PM
whitehooptie
Jul 12, 2015 06:10 PM
CARiD
Jul 7, 2015 08:19 AM
surreybrad
Jul 5, 2015 10:36 PM
