Install of a pre apmed MTX thunderform box?
Old May 22, 2004 | 06:31 PM
MidnightBlue 98's Avatar
Hello all I just got an MTX thunderform pre amped sub box. Now with the amp inside the box it has the outlets on the back of the box. I know I can't just splice into the other speaker that is back there. If I run it into the factory head unit is there an outlet on the back of the factory head unit? Also do I have to run a power supply all the way to the battery, and if so is there a pre drilled hole somewhere in the firewall or does one have to be drilled?
Thanks
Old May 23, 2004 | 06:14 AM
LS1 RULZ's Avatar
Information found here should tell you pretty much everything you need to know about installing a stereo in an F-Body.
Mar 13, 2016 03:39 PM
MadMav
Feb 6, 2015 11:02 PM
phatbasslines
Jan 13, 2015 05:03 PM
Bando
Oct 7, 2002 07:36 PM
Snake Slayer
Jul 29, 2002 12:39 PM
