Ssra
Old May 20, 2004 | 10:59 PM
Articblast's Avatar
Ssra
What is a SSRA.
Old May 20, 2004 | 11:49 PM
gav'spurplez's Avatar
Super Sucker Ram Air. awesome mod. it is like the fast toys ram air but has a lower scoop that sucks the air up into the box.
http://www.lmperformance.com/1858/1.html
Old May 21, 2004 | 02:34 AM
coogsLS1's Avatar
SSRA =
get it asap
Old May 21, 2004 | 04:31 AM
camaronutt's Avatar
Thanks
Thanks for that question, and thanks for the answer. I have seen that abbreviation on here a lot and never knew what is was. now i know. new LS-1 owner here.
Old May 21, 2004 | 06:51 AM
teke184's Avatar
i have a couple pics of it installed on my 99z on the webpage in the sig
great mod, incredible gains on the highway
Old May 21, 2004 | 10:36 AM
Articblast's Avatar
I have the SLP Cold Air Induction. Is that pretty much the same.
Old May 21, 2004 | 12:27 PM
teke184's Avatar
same idea, but i don't think as effective. the SSRA scoop is lower and actually catches air from under the nose. the SLP and FTRA are more of a cold air kit, relying on drawing air from under the nose instead of it being "rammed" into the scoop.
and the SSRA is plastic, so it is less of a heat soak, and a bit more forgiving if you hit something
Old May 21, 2004 | 12:55 PM
Articblast's Avatar
Thanks
Old May 21, 2004 | 08:33 PM
Buffdaddy's Avatar
I can not wait for my ssra!
Old May 21, 2004 | 11:15 PM
i have noticed the car running hotter even though it is plastic. in traffic and stop and go, it goes to about 210. once you start driving or if you are on the highway is is lower. fan switch ??
Old May 22, 2004 | 09:54 AM
1stls1's Avatar
Do you have a problem w/ rain getting in. How does this hook up w/ the lid?
Old May 22, 2004 | 06:57 PM
no problems in rain, even downpours. only thing you need to watch for are the huge puddles of standing water, that would be bad
I got the lid, ssra and bellows at once and could feel the negine breathing easier right away. the ssra fits along your radiator and slips in under the filter tray, so the lid goes on normally
Old May 22, 2004 | 07:17 PM
1stls1's Avatar
So on a 99Z,no cutting.
Old May 22, 2004 | 07:22 PM
the only thing that you have to cut is the bottom of the air box housing. like the free ram air mod. nothing big
Old May 22, 2004 | 07:23 PM
i think www.installuniversity.com
this should have the instructions for the FRA mod and pictures
