Need some help w/keyless entry
Old May 20, 2004 | 03:46 PM
gamecockfan04's Avatar
OK, I bought a Commando Keyless Entry system over a year ago and have still yet to figure out how to hook it up. Can someone please help me, or would it be easier to find a transmitter from a 94'-95' TA and use the factory system? Would the factory system plug right up, or would it require, some configuring?
Old May 21, 2004 | 01:50 AM
Javelin3o4's Avatar
the 95 bird has a 5 wire locking system, check www.12volt.com for how to wire up the relays. Here are the notes directed supplies when hooking up the relays though.
on-keyless versions: Use light blue for lock and dark blue for unlock. Both wires are located in either door harness. The passenger switch is the master switch. Keyless versions: Use red/black for lock and orange/black for unlock. Both wires are located in the passengers kick panel at the keyless entry module. Do NOT use the orange power wire at the keyless module or door lock switch to power your door lock relays. The passenger switch is the master switch.
Old May 21, 2004 | 07:50 AM
What exactly do I need to click on on that link to see what I need to see.
Thanks for the Reply,
Old May 21, 2004 | 07:56 PM
Brent94Z's Avatar
Super Moderator
You can also download the zip file on this page for the 93 to 95 F-Body. Should have the info in there you need!
http://www.bfranker.badz28.com/fbody/alarm.htm
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
WPHIG2
Aug 27, 2015 06:37 AM
bunker
Aug 21, 2015 10:21 AM
gelbza
May 29, 2015 05:50 PM
