Anyone have some T56 stuff laying around?
Old May 15, 2004 | 10:21 PM
dreamer1q's Avatar
I need a few pieces I dont have in the salvage yard right now. Mainly a dust shield, cross member, upper shifter section, and the slave unit. Somebody has to have this stuff laying around. Its not very often the junk yard dog has to ask for parts
Q
Old May 16, 2004 | 11:38 AM
Rodrigues's Avatar
That stuff isnt expensive from GM
The crossmember is only $20 or so from GMpartsdirect and $21 from cromar... Then I have a dust shield if you need it and what do you mean by upper shifting section? Shift forks and the shifting rod assmembly?
Old May 16, 2004 | 07:53 PM
dreamer1q's Avatar
I will take the dust shield for sure. The upper section I mean is the part that actually bolts to the factory shifter that goes into the tranny. The part the shift **** attached to. You know where the shifter splits on a factory shifter, I need the upper section that dosent bolt to the actual tranny. Ya got anything else laying around? I believe Sean is gonna be making a trip over here soon, maybe we can get him to play parts bitch again
Q
Old May 16, 2004 | 09:43 PM
mavricki18's Avatar
I think i still have my 98-00 slave layin around
Old May 16, 2004 | 09:48 PM
dreamer1q's Avatar
I wish I could use it, but I believe the LT1 is different. Thanks though
Old May 16, 2004 | 09:59 PM
cASe SenSiTive's Avatar
Exposed Member
I think I have a spare slave in my garage. I know that I threw out my stock shift-lever during spring cleaning.
Old May 17, 2004 | 12:19 AM
AL SS590 M6's Avatar
Hey Q, I've got the stock shifter out of the SS. If the stick is the same we could work something out.
Old May 17, 2004 | 05:12 AM
dreamer1q's Avatar
Excellent, Tom and Al, I would be willing to take both of them off your hands.
Old May 17, 2004 | 07:48 AM
Rodrigues's Avatar
What are you doing exactly?
Old May 17, 2004 | 08:20 AM
dreamer1q's Avatar
Just never you mind Secrets Boy What you want for the dust cover I need it.
Old May 17, 2004 | 08:45 AM
PhantomTA's Avatar
Yes you need an lt1 slave Q...
Old May 17, 2004 | 08:46 AM
95 Z/28 LT1's Avatar
Super Moderator
If you are going to use the trans in anything you actually care about I would recommend a new slave assy. from GM. They're cheap.
Old May 17, 2004 | 08:53 AM
PhantomTA's Avatar
I would agree Q. Pick up a new one.
Old May 17, 2004 | 09:19 AM
dreamer1q's Avatar
Ok, I didnt realize they were cheap. Plus I wanted to see if I could use a newer one or not Thanks guys
Old May 17, 2004 | 09:42 AM
Super Moderator
The one you get from GM comes with everything and is pre-bled.
There is an old part number, 10230433, and a new one, 12557509. I don't know what the diff is though. I've replaced mine before with a new one, but I don't remember which one i used.
Edit:
10241153 Flywheel Cover
12337973 Flywheel Bolt. (Need 4)
