Anyone have some T56 stuff laying around?
I need a few pieces I dont have in the salvage yard right now. Mainly a dust shield, cross member, upper shifter section, and the slave unit. Somebody has to have this stuff laying around. Its not very often the junk yard dog has to ask for parts
Q
Q
That stuff isnt expensive from GM
The crossmember is only $20 or so from GMpartsdirect and $21 from cromar... Then I have a dust shield if you need it and what do you mean by upper shifting section? Shift forks and the shifting rod assmembly?
Q
The one you get from GM comes with everything and is pre-bled.
There is an old part number, 10230433, and a new one, 12557509. I don't know what the diff is though. I've replaced mine before with a new one, but I don't remember which one i used.
Edit:
10241153 Flywheel Cover
12337973 Flywheel Bolt. (Need 4)
Edit:
Thanks though
I need it.
