Cruise Control
Old May 8, 2004 | 10:22 PM
JoeliusZ28's Avatar
Question Cruise Control
My cruise control decided to stop working today... anything I check like a fuse or do I have to buy an entire new unit? (mainly... what fuse do I check?)
Old May 8, 2004 | 11:25 PM
ishz28's Avatar
See if your third brake light is burnt out, it rides on the same circut as the cruise does.
Old May 8, 2004 | 11:39 PM
JoeliusZ28's Avatar
Thumbs up
thanks I will try that first thing tomorrow
Old May 9, 2004 | 10:12 AM
JoeliusZ28's Avatar
third brake light still works...
thats probably bad news
Old May 9, 2004 | 05:30 PM
ishz28's Avatar
Ok, does your a/c still work? I have a bad compressor, everytime I moved the HVAC fan control past any off the a/c settings to regular fan settings, it would blow the fuse in the engine bay fuse box. I just unplugged the a/c at the unit. Anyway, still check the fuses in the engine bay.
Old May 9, 2004 | 05:34 PM
JoeliusZ28's Avatar
ill try the ac thing and all the fuses while im at it.
Old May 10, 2004 | 03:15 PM
JoeliusZ28's Avatar
have not gotten a chance to check that yet... im really busy with schoolwork today
Old May 10, 2004 | 03:19 PM
Capn Pete's Avatar
It could just be that the switch is screwed. F-bodies use the exact same switch that older GM trucks used, and a lot of them (switches) die. I know we had that with my dad's old truck, and his friend at work had the exact same problem too......the cruise still worked, but with a new switch.
Old May 10, 2004 | 07:04 PM
JoeliusZ28's Avatar
Is that so? My truck and car have the exact same blinker handles. Niether work now. But it would be nice to pay $5 per vehicle to fix them as opposed to $200 a piece.
Old May 11, 2004 | 04:39 PM
JoeliusZ28's Avatar
AC is working fine, but I havent checked the fuses yet
Old May 12, 2004 | 01:41 AM
Lower's Avatar
Did you take it off to check it? There are 2 bulbs there IIRC, which means you might still get light out of it, and still have one burned out, rendering your cruise control unfunctional.
Old May 12, 2004 | 01:39 PM
Joe Bellman's Avatar
I was in autozone the other day they had a few of the turn signal switch assemblies for sale on a shelf. they are priced much cheaper than the ones from the GM dealer.
Old May 12, 2004 | 09:54 PM
JoeliusZ28's Avatar
Red face
well guys...
today the cruise control decided to magically heal itself... hope thats not a warning sign. Thanks for the suggestions though, because the switch might be all my truck needs
Old May 13, 2004 | 10:15 AM
iNF3RNo's Avatar
I have an interesting issue with mine. Takes some cajoling to get it to work.
I have do this:
-Pressing the throttle in some
-Hold the button in (to the right) until it engages and then still hold it in a little more, while I'm still accelerating. If I let off too early, the cruise will come off. Sometimes I will have to keep pushing it in (it not engaging wasn't b/c I didn't hold it in long enough - it just wasn't going to work that time.)
-Have to be going 5-8mph under the speed I intend on setting the cc at, because of how I have to hold it in before it will "stick."
-Playing with the other buttons on the stick helps too...
Basically I avoid hitting the brakes.
Old May 14, 2004 | 12:02 PM
Capn Pete's Avatar
^ ^ again, sounds like your switch is dying, since it's getting harder and harder to set (and it's not that it won't work, it's just hard). I think the connections inside the switch must be cheap and wear out to the point they don't make good contact anymore?
