Ready to Rumble
Old May 2, 2004 | 10:05 AM
TrouserSnake's Avatar
Ready to Rumble
Today the Car will be started... for the First time in a while...
Just added Hooker Lt's - XE 230/236 - 1.6 rr's - new valve springs - pushrods - plugs and wires.
Today all I gotta do Is put the starter in. Adjust the lash and all the little things like radiator, altrenator and find where all the hoses and wires plug in...
Anything I should look for before I crank the Key?
Old May 2, 2004 | 10:08 AM
KGRESOCK's Avatar
Bleed the cooling system before you fire ,lot of guys
seem to forget that.
Best of luck to you
Old May 2, 2004 | 11:04 AM
98cayenne-Z's Avatar
cool........midland........
were neighbors................
see ya around the big ole tri cities......
Old May 2, 2004 | 02:33 PM
MBonZ28's Avatar
your in for a treat when you hear those duals!
Old May 2, 2004 | 06:45 PM
dreamer1q's Avatar
Best of luck to you
How the hell do you do that before you fire it? You mean just fill the waterpump?
Old May 2, 2004 | 07:20 PM
ok my buddie is comming over to do the final adjustments before we get it going... (plugs and wires)
now.. When I adjust the RR's do you guys do it when its running? or turn the crank and adjust them?
Old May 2, 2004 | 08:45 PM
IROC5.7TPI's Avatar
Turn it over by hand and adjust the lash... otherwise you'll have oil everywhere.
Old May 2, 2004 | 10:06 PM
stereomandan's Avatar
Even if you adjust them with the engine on and the valve covers off, you need to have done it with the engine off first.
Doing it with the valve covers off is like a fine tuning.
Dan
Jeff1904
Jun 5, 2016 05:00 PM
Bigfatrat
Parts Wanted
Oct 4, 2015 08:54 PM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
z28newbie
Sep 9, 2015 10:26 AM
ChrisFrez
Sep 9, 2015 06:52 AM
