Do L.E.D.'s get HOT?
Old Apr 26, 2004 | 11:52 PM
guitardedjf's Avatar
do LED's get hot ? if so, can they melt plastic? are they MOISTURE sensitive?
I'll be doing all of my interior lights in LEDs pretty soon, So i am curious.
Old Apr 26, 2004 | 11:55 PM
AW/whiteZ-28's Avatar
They get warm but not hot enough to melt plastic. None I've used have anyways
Old Apr 27, 2004 | 12:17 AM
Red96Lt1's Avatar
As long as the connections are water proof, so are the actual LED's. And yes, they do not get hot. It only takes a few volts to actally turn them on.
Old Apr 27, 2004 | 04:57 AM
Drumhawk's Avatar
Re: Do L.E.D.'s get HOT?
Originally posted by guitardedjf
do LED's get hot ?
Old Apr 27, 2004 | 06:50 AM
97FormulaWS-6's Avatar
The LEDs you are most likely to use don't get hot... (5mm, t-1 3/4)
There ARE LEDs that get VERY Hot... I work with LEDs all day, and I have some that will burn you from touching parts of the LED and its required Heatsink.
Old Apr 27, 2004 | 09:34 AM
I'm going to use the plug and play ones from superbrightleds.com..... the ones with the resistors already built into them....
I think I only need 3 and 5 mm so I guess they should be cool... thanks for your input guys!
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
damnyankee36
Sep 9, 2015 07:06 PM
