Cam Selection for my setup
Old Apr 19, 2004 | 11:43 AM
MEAN_SBC's Avatar
Okay, I've decided to go with a solid roller cam in my Camaro.... I just need a little help in deciding which cam to go with.... My engine is a built 383 stroker with -
10.0:1 JE Pistons
JE HNS Rings
Scat 4340 Crank
Scat 4340 6.0 I Beam Rods
Dart Pro 1 Aluminum 215cc heads
1.5 Roller Rockers
Hedman Husler 1 3/4" headers, Flowmaster 3" exhaust
Hughes GM92 3500 Stall Converter, TH350, 3.90 rear gears
NX Gemini Quad Nitrous System... Dual Stage 350 shot...
Currently I'm running a Comp NX284 Nitrous HP Hydraulic flat tappet cam, and I don't really like the all motor performance of it... I want a little more pep on motor only.... The car is a very limited street driven vehicle, and streetability isn't a huge issue...
Here's a pic of the car for an idea.. http://amarilloracers.com/images/stock.jpg
Thanks for any input.. I appreciate it..
Old Apr 19, 2004 | 11:50 PM
justens95z's Avatar
I've got a Lunati solid roller in my Nova, and I really like it. It is only .591/.597. You have a little better heads than I do, so I would think go with the .630 lift Comp cams. They make a lot of the .630 lift cams with different LSA and duration depending on where you want the power to come in at.
Old Apr 20, 2004 | 12:43 AM
talos's Avatar
uhhh... a 630lift cam in a SBC well keeping it streetable... ya good luck.
What are u wanting to do with this car? Track only? Street/strip?
Old Apr 20, 2004 | 10:24 AM
MEAN_SBC's Avatar
It does get cruised a little on the weekends... I think .630" is a little too radical for me... I was lookin right around the .600" or lower area... The heads on my car don't really come alive until right around there.... I know that the cam I have right now doesn't have enough lift (.525", .507"), and I'm also looking forward to the rest of the benefits of a solid roller... I want to rap it out to about 6500-6800 rpm.... Thanks...
Old Apr 20, 2004 | 02:42 PM
talos's Avatar
if u don't know about this website go here and ask all ur 2nd gen questions there...
nastyz28
go there and ask and by the end of the day u will have many replys.
Dec 1, 2016 05:37 PM
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
alex5366
Feb 17, 2015 08:12 PM
