Need help asap!!
Old Apr 12, 2004 | 01:36 PM
Rybar's Avatar
Need help asap!!
Johnny, Matt, Mike and Payam, check your inbox's please.
Can anybody tell me some simptoms of a bad opti? Would it cause a car to die, and not be able to start (ie no spark)
Let me know asap!!
Thanks
Old Apr 12, 2004 | 01:41 PM
BPS's Avatar
BPS
opti's usually but not always start with a bit of a miss and surging that gets worse over time.
if something happened suddenly - and you haven't spray washed the engine and it's ignition relater (no spark ) I'd check the fuses and coil first.
Old Apr 12, 2004 | 02:05 PM
Jason Dove's Avatar
And take a good listen to make sure the fuel pump is still priming when you turn the key to the on position.
Old Apr 12, 2004 | 02:39 PM
bunker's Avatar
Like I said, check your fuses, if your injectors are firing then the opti optical section is fine, if you say you smell it then obviously they are firing. Now check for spark at the coil not the opti, if no spark its either the coil/fuse/ignition module.
The ignition module is the little black thing with a plug right above the coil.
Matt.
Old Apr 12, 2004 | 03:28 PM
sideways_Into_3rd's Avatar
I never got anything in my inbox
but if ur car isnt starting at all ... id check the fuses first as mentioned .. could also be the opti .. when the opti first went on my 94 it wouldnt start either
also check ur opti harness for rust (blue green colored rust) .. i got a spare harness if ya want
Old Apr 12, 2004 | 05:06 PM
JD30thZ28's Avatar
Coil or Ignition Module I sent you an e-mail.
Old Apr 12, 2004 | 05:07 PM
DoubleJ's Avatar
sounds like the same problem i had a month ago, my car all of a sudden decided not to start i changed my coil and it still didnt start, turned out to be my fuel pump just listen for your pump when you turn your key
Old Apr 12, 2004 | 05:17 PM
ollie-99's Avatar
sounds liek what happend to me @ the last meet
lol
but it was somthing dumb
Old Apr 12, 2004 | 06:37 PM
Rybar's Avatar
Fuses are OK, and there is spark at the coil and the plugs but very weak, there is fuel, the pump primes and I get ~ 40 psi on my fuel pressure guage. But the pump I am hearing is the secondary inline pump for the blower.
Any other suggestions?
Payam, I sent it to your hotmail. I may need that harness off you.
Old Apr 12, 2004 | 07:28 PM
BPS's Avatar
BPS
bypass the MSD box
Old Apr 12, 2004 | 07:41 PM
Goblin355C4's Avatar
could be ur msd box...mine was messed up and the car wouldnt start.
Devinfoote87
Sep 4, 2015 05:52 PM
asilomar244
Jul 12, 2015 05:53 AM
james4154
Jun 15, 2015 12:16 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
