how to raise the back end a bit ?
Old Apr 11, 2004 | 03:41 PM
sideways_Into_3rd's Avatar
I have the prokit in my car right now . and i think that the back end is a little too low (for my liking) and bottoms out a little bit here and there
can i slip a garden hose in my rear springs to raise it up a bit ?
any other methods to raise the back about half an inch ?
Old Apr 11, 2004 | 03:44 PM
Xride's Avatar
Re: how to raise the back end a bit ?
The SS SLP springs have something like that on them, but dont know if its to raise it up or anything though.
If nothing else I saw somewhere had like a shim kinda that raised the rear .5" I think it was.
Old Apr 11, 2004 | 03:45 PM
yeah .. a shim would be wicked .. hopefully that person chimes in ... I wonder if its a rubber shim or steel
Old Apr 11, 2004 | 03:50 PM
Xride's Avatar
you could make a shim couldnt you?
hmm, or you could cut the mount off the axel tube and weld it on higher, but that seems like alot of work.
Old Apr 12, 2004 | 04:20 PM
Janny's Avatar
I made a shim out of 1/2 inch thick conveyor belt. Good sturdy stuff, but now I need to raise the locating dowel because there is nothing to hold the spring in place. I figured maybe get a muffler shop to weld on wee peice of pipe and I'd be all set.
Old Apr 12, 2004 | 04:57 PM
LPEdave's Avatar
*chime*
I made shims from UHMW plastic that I put on top of my rear springs. Did it to level the car side-to-side, and also to raise it when I drag raced. Works like a champ.
Take a look toward the bottom of http://www.go-fast.org/z28/suspension.html for some info.
Dave
Old Apr 13, 2004 | 10:16 PM
Shue97_Z28's Avatar
LPEdave, thats a great idea. I sent you an email asking you a few simple questions. Im usually pretty handy when it comes to ideas like that but I would have never thought of that. thanks man, your knowledge is greatly appreciated.
ChrisFrez
Dec 28, 2014 02:25 PM
ChrisFrez
Dec 15, 2014 03:09 PM
siguy
Nov 27, 2014 10:07 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
