Shifting Issue
Old Apr 11, 2004 | 02:08 PM
CrockRocket94's Avatar
Shifting Issue
The Problem: At WOT runs the car has problems on the 2-3 shift where it will seem to "stick" at about 6200 rpm, and just kind of "bucks" without going into the next gear and I have to let off the gas to allow it shift. It only seems to do this on the 2-3 shift as the 1-2 is smooth.
Under medium acceleration the shifts are excellent and no problems whatsoever.
Mods on the car are Shorty Headers, 3.73 gears, K&N CAI, Hooker Catback, SLP Speedo Recalb. and a lt4 KM.
The PCM has never been retuned after the mods have been put in.
Would a PCM tune for different shiftpoints and or firmer shifts releave the car of the 2-3 "sticky shift" problem?
Old Apr 11, 2004 | 02:24 PM
NewbieWar's Avatar
ur probably having some kinda of power loss that it cant reach the rpm's u set it to... it could be anything from bad wires to a clogged cat.
Old Apr 11, 2004 | 02:30 PM
z28poweredlt1's Avatar
Re: Shifting Issue
computer tune might do you the trick, I've heard of it fixing that problem before on the forums.
Old Apr 11, 2004 | 02:50 PM
I am suspecting a tune would due it good, even if it didnt fix the shifting issue.
The car does not have a power issue as it pulls like a bat out of hell throughout the RPM range..
I have a vid of the Tach sticking uptop if anyone wants to host it.
its ~9.2 megs
Old Apr 11, 2004 | 11:08 PM
its ~9.2 megs
Try the tune and keep us posted on what the outcome is.
-Mark
Old Apr 12, 2004 | 08:45 AM
Can do!
-Craig
Old Apr 12, 2004 | 09:19 AM
aintno6's Avatar
What did you have before the 3.73's?
I had 2.73's. Car never hit rev limiter before it shifted. Well I had some 3.73's put in. Went to the track to get a pass. Well the car would hit rev limiter before it shifted into 2nd. And did the same thing before it went into 3rd. So I go take it to a local shop. And have them edit the pcm.
Well they edited the gear ratio but didnt lower my shift points. So when I went back to the track it shifted fine into 2nd. But when I went to go into 3rd it did the same dam thing. Its the same thing your talking about. So Im editing my shiftpoints hopefully this weekend.
I was told that when you go from such a big leap of a gear, the whole shift tables need to be lowered. And it makes sense because the pcm makes the a4 shift based on mph not rpm.
Old Apr 12, 2004 | 10:08 AM
Brent94Z's Avatar
Super Moderator
Sometimes a slipping tranny can cause that... the RPM goes up as it slips but the car doesn't get the the MPH it needs to get to shift so you end up hitting the rev limiter. Hopefully that's not it
I'll move this to the Drivetrain forum for ya...
Old Nov 15, 2004 | 06:28 PM
Re: Shifting Issue
Just a follow up report on the issue.
It turned out the tranny was going bad, and the effect was the tranny not wanting to shift and slipping real bad in 3-4.
4th gear finally went out and it just free reved in 4th.
Thanks for all the input but it turned out to be a bad tranny.
PCLZ28
Dec 24, 2015 05:19 PM
Apr 16, 2015 09:57 AM
BigWil
Mar 29, 2015 12:24 PM
jackpawt883
Feb 26, 2015 09:04 PM
armedtrigger
Feb 24, 2015 08:30 PM
