sub frames
Old Apr 8, 2004 | 09:10 AM
raz0r6's Avatar
sub frames
hey i have a red underbody neon kit on my car right know will i be able to in stall sub frame conectors and keep my neons on as well?
has any one done this?
plus do the sub frame conectors really work?
i also read something that if you jack up the front passanger side on your camaro after haveing the sub frame connectors on that 3 wheels will go up in the air? what does this have a purpose for?
kyle
Old Apr 8, 2004 | 09:30 AM
v7guy's Avatar
you might need to reposition your neons, but yes you can have both
yes subframe connectors really work, your question about three of the wheels lifting leads me to believe that you don't actually understand what the subframe connectors are doing.
your car right now has a substantial amount of flex in it, as you corner or jack the car up, the body of the car physically twists and bends, jacking up a corner of the car you will notice that the cars wheels do not all come up, it's because the body of teh car is twisting, the same thing is happening when your conering, the body gives and twist. By adding in subframe connectors your tying together the two halves of the car, and making it more rigid, and not allowing the car to flex, so with them you'll jack from a corner and three of the tires should raise if you get high enough, the body is also not twisting when you corner resulting in more precise handling.
Old Apr 8, 2004 | 09:57 AM
raz0r6's Avatar
there fore in proving traction and giving me better control.
like if i want to whip it around the corner i wont loose control of the car, it will give me a tighter and more control over the car
wow i cant wait to get some
what brand do you recomend?
kyle
Old Apr 8, 2004 | 10:10 AM
v7guy's Avatar
you'll have more control over the car in the aspect that it will be more consistent in it's handling, you'll be able to accurately determine where it's limits are better because it will be more consistent.
as for which style you go for it all depends on your set up, alot of guys end up going with the SLP bolt in subframes and then they weld them in.
You could also just go with the SLP weld in as long as you paint them well after they are in.
Regardless the SLP pieces are the only ones the tie the center of the car in as well as the front and rear that pretty much everyone agrees is a good design, or at least the best design that is currnetly offered. This design will limit exhaust setups, some drive shaft safetly loops torque arms etc
there are various tubular and boxed SFC as well that vary with how far down they stick and how much they cost
typically it is advised to weld the rocker panels into the subrame connectors though as it tightens the car up more and makes better use of the subframes
Old Apr 8, 2004 | 12:36 PM
Xride's Avatar
Paint them BEFOR they go in, let the welder grind off where he has to.
it makes it SO much easier.
I also have and love the SLP weldin's, best mod yet, makes alot of hte creaks and rattles out of the car when jsut driving too.
Old Apr 8, 2004 | 01:19 PM
raz0r6's Avatar
what about a torque arm from Bmr does that do alot as well?
can you tell the difference with a torque arm
Old Apr 8, 2004 | 01:35 PM
Xride's Avatar
I hear different stories all over about tq arms, but generally for corners they dont help, and even for drag racing they do more help when you are on slicks then street tires.
Old Apr 8, 2004 | 02:29 PM
Tang's Avatar
The Kenny Browns also tie in the center as well as front and back. I had those on my old IROC and they were the best thing I had ever done to that car. As soon as I save up some money I plan on buying some subframe connectors for the 95. Which ones, I'm not sure yet.
Old Apr 8, 2004 | 02:42 PM
raz0r6's Avatar
what track man i live in south bend you got to Osceola drag strip
hey if your ever up on micknely man look for 95 black camaro 4inch cowl lowers quad exhaust
is there anyone else on the message board from northeren IN.
Old Apr 8, 2004 | 03:12 PM
Tang's Avatar
Ya, I goto Osceola...I'm suppose to go there on a Friday night within the next few weeks with some guys at work.
Actually I think I've seen you around before, not around McKinly though. Something about all those cops on Friday and Saturday nights makes me a little nervous.
They're are a few people from around this area that I know of. I only know one of though, because he went to my high school and graduated like a year ahead of me. He lives in Osceola and drives a 99 Z28 with 214,000 miles. My Camaro is plain as stock looking...so far. I'm getting the bumper and hood repainted this summer and I'm going to put some 30th anniversary strips on it. We'll have to meet up sometime.
Old Apr 8, 2004 | 03:30 PM
raz0r6's Avatar
sure man mines really not all that special engine wise(v-6) hahahah yea but i got tons other mods done custom paint job just an overal clean stock car its my baby and i take care of her i live less then 6 blocks from Iusb i live in river park?
maybe we could meat up sometime at the track or at micknely or something
get back with me i n the summer
kyle
Old Apr 8, 2004 | 04:51 PM
Tang's Avatar
Alright, sounds good man.
Old Apr 8, 2004 | 05:49 PM
v7guy's Avatar
there is a lot of debate as to the usefulness of the kenny brown SFC hence my comment the slp ones are the only ones everyone can seem to agree on being a good design
Old Apr 8, 2004 | 06:00 PM
Tang's Avatar
Oh ok, I haven't really heard the debate, I guess thats why I didn't know. Is there really that big of a difference? They both looked pretty similar to me.
Old Apr 9, 2004 | 03:22 AM
Meccadeth's Avatar
You rang?
I haven't seen your new Z yet...
I might this next semester though, I'm starting over at IUSB
On Topic - Sub Frame Connectors take a lot of the rattles out of the ride right? Thats what I've heard from some people but I'm still a little confused about them. They cure rattles and tweak handling a little bit is what my general idea of them is. Structural rigidity is always a plus too...
