What do you think of this setup?
Old Apr 3, 2004 | 02:17 AM
killer305's Avatar
327 w/ forged pistons, pink lt1 rods,billet crank.
Machined vortec heads for higher lift.
10.5:1
Comp Cams XE284H 240*/246* .507"/.510" 110 lope separation
speed demon 650 w/ vacuum secondary
pro-products "hurricane" intake
crane 1.6 rockers
direct port nitrous.
2800 vigilante
What do you guys think, any sugestions?
Thanks
Old Apr 3, 2004 | 02:19 AM
DarthIROC's Avatar
Id go with a little more stall like 3200 and a mechanical sec carb. And why a 327?
Old Apr 3, 2004 | 02:48 AM
97WS6SCharged's Avatar
If you must use the pink rods, make sure you invest in a good set of ARP rod bolts and a stud kit for the mains.
Old Apr 3, 2004 | 01:47 PM
killer305's Avatar
i got the 327 for free
so do you guys have any comments
Old Apr 3, 2004 | 02:03 PM
dj haf's Avatar
sell the 327 and buy a 350-383 or something better
Old Apr 3, 2004 | 02:09 PM
DarthIROC's Avatar
What year 327 is it? If its a large journal it has the same bore and main journal size as a 350 you can just use a 350 crank, or a 3.75stroke crank if you want.
Old Apr 3, 2004 | 06:37 PM
killer305's Avatar
not an option, besides a 250 shoot should overcome the power lost by displacement
Old Apr 3, 2004 | 06:39 PM
killer305's Avatar
i dont have a 327 block, i have a 327 billet crank for a 350 block
Old Apr 3, 2004 | 06:48 PM
DarthIROC's Avatar
Oh ok. Well if you got an expensive crank given to you I guess I can see that. ALthough you can probbaly sell the crank to a vintage guy who wants to keep the stock cubes but needs a tougher crank, and buy a bigger one for yourself if you really wanted to.
Old Apr 3, 2004 | 07:25 PM
AutoRoc's Avatar
IS this a race car or cruiser? Daily driver? Looks like you're going to be doing a little racing so I'll lean towards that aspect, k?
Yeah I wouldn't put Pink rods in between a billet crank and a good forged piston. At least invest in a set of Scat or Eagle I or H beams with good bolts, especially if it's going to see some rpm and nitrous tickling.
I would do a Super Victor Vortec over a dual plane with this kind of combo and have it port matched accordingly. Steel Comp Pro Mag rocker arms instead of Crane Alum. pieces might be safer again if you're going to be seeing big rpm.
A custom torque converter like a P.I. Vigilante is a great idea. I would also go with a 3000-3200rpm piece specifically built for hevay nitrous use(nitrous has a huge effect on torque converter selection because when you hit that button IT'S A WHOLE DIFFERENT BALLGAME)
Goodluck! Sounds coooool!
Old Apr 3, 2004 | 08:31 PM
killer305's Avatar
racecar/cruser alright it looks like i will upgrade the rods. The intake i got is a knock of of the victor JR, its a single plane high rise race manifold.
Old Apr 3, 2004 | 10:28 PM
AutoRoc's Avatar
Ok cool. Now is that knock off going to bolt to Vortec heads or do you still need a Vortec compatible piece? *chant on* Su-per Vic! Su-per Vic! *chant off*
Old Apr 4, 2004 | 02:16 PM
killer305's Avatar
no its vortec compatible.
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
FryedClutch
Sep 1, 2015 08:24 AM
detroitmuscle
Jul 31, 2015 04:21 AM
