scratches
Old Apr 3, 2004 | 12:40 AM
bigfoot2471's Avatar
scratches
first my car went under a chain link fence. That is at least what i was told happened before i bought it. Anyways it made lots of small scratches on the car some visable some hard to see. and i also have some scratches were the clear coat was taken off. To top it all off somebody thought it didnt have enough scratches and decided to add a couple more small ones with there keys. those scratches took off paint so they are white unlike the rest of the scratches. The car also came with a bra just on the hood. I took it off but it sort of faded and scratched it. I am wondering what products to use to try and hide these marks. I am planning on repainting the whole car but that wont happen for awhile. I have tried a couple products already with no effect. I tried that gs27 crap just to see and the turtle wax stuff with the chipstick and color match liquid. Thanks
Old Apr 3, 2004 | 12:48 AM
chasmanz28's Avatar
Re: scratches
if the scratches are as deep as you say they are nothing is going to take them out but a new paint job, if there not deep only suface you could use a high speed buffer and some rubbing compound
Old Apr 3, 2004 | 07:13 PM
some of the scratches i will be able to get out hopefully. what rpm buffer should i get. i went looking and i found a couple different speeds. there was a 2800 and 3800 rpm would the 2800 be fast enough for what i need. i saw the tutrle was rubbing compound for like 2 bucks is that stuff any good. thanks
Old Apr 3, 2004 | 11:57 PM
chasmanz28's Avatar
if your good with a buffer get the higher speed, but becareful not to burn the clear, if you are worried about or dont have much time with a buffer in general get the slower speed, anyway you look at it you must take your time and just dont stay in any spot too long, good luck
Old Apr 4, 2004 | 01:45 AM
thanks for the info. i think i will just go with the lower speed plus it has an inch bigger pad. thanks for the help its apreciated.
Old Apr 4, 2004 | 07:37 AM
transamgirl95's Avatar
make sure u use a foam pad not a wool when using the buffer and if it doesnt work look for a detail shop that does wet sanding i am a detailer and i knwo how hard scratches can be to remove . wool pad scratch the paint cause swirl marks ...good luck
Old Apr 4, 2004 | 11:13 AM
Black_Z28's Avatar
Why not get a orbital buffer. They're the ones that seem to shake while you buff your car. They move like that to prevent you from sitting in one place for too long. Which will not allow you to burn your paint. I think orbital buffers are the best one to buy if you're a beginner.
Old Apr 4, 2004 | 06:47 PM
chasmanz28's Avatar
true but there only good to do a polish job not to take out marks in the clear, before i would buy an orbital ide wax the car buy hand, JMO
Aug 17, 2015 09:50 AM
surreybrad
Jul 29, 2015 02:55 PM
Fastbird93
Jul 11, 2015 04:37 PM
hoozenxt
Jan 27, 2002 05:03 PM
SSRox
Aug 29, 2001 06:52 PM
