using throttle plate with nx wet kit
Old Apr 2, 2004 | 05:57 AM
jeremyferguson's Avatar
I was considering using a n.o.s. brand nitrous "fogger" plate that goes behind the throttle body. It has a bar for nitrous and a bar for fuel.....has anyone else used them. Do they provide a more uniform dispersion of n20/fuel into the intake as opposed to a shark nozzle in the intake elbow? Will it even work??
Will I have to get longer throttle/cruise control cables?
Any info would be appreciated!
Old Apr 2, 2004 | 10:07 AM
94Zpower's Avatar
I am putting a plate from 5150 kit ( TPI motor) on my LT1 and from what Ican see it should work fine! nitrous works has a plate system for the LT1 and it works ..so there should be no problem.
Old Apr 5, 2004 | 12:54 PM
chevy1963's Avatar
I use the plate system, and its much better them just using a fogger nozzle, using the fogger your taking a chance of locking up your injectors. I still have cruise and and everyting. you'll just have to adjust the throttle cable
Old Apr 5, 2004 | 11:55 PM
Thanks, those are the answers I was looking for
Old Apr 6, 2004 | 05:08 AM
RacinLT1's Avatar
not true at all. if you use a DRY fogger you stand a chance of locking up the injectors.
i ran the nx nozzle with up to a 175 shot,and had no problems. stock longblock went 11.02@124
Old Apr 6, 2004 | 07:05 AM
chevy1963's Avatar
Isn't that what I said? using a dry fogger nozzle you stand the chance of locking up the injectors??
Using the plate for the WET application is a better way to go.
Old Apr 6, 2004 | 12:17 PM
Slow95T/A's Avatar
anyone ever used a plate like this with two nos nozzles
its just like the tnt kit just diff location for the nozzles
Old Apr 6, 2004 | 12:20 PM
chevy1963's Avatar
nope, mine comes in from the side, I have one nitrous line and one fuel line
Old Apr 6, 2004 | 09:44 PM
RacinLT1's Avatar
chevy1963,actually you didnt specify "dry" fogger in the first post,you merely stated fogger.
I ran a wet fogger,and it outperformed my wet plate by a long shot.
Slow95t/a,thats the original NOS plate they came out with for TPI cars,that was around for a few years then they went with the much better twin bar plate.
also most plate systems come with spacers to move the entire throttle bracket forward (matches thickness of the plate) so no adjusting needed.
Old Apr 7, 2004 | 12:57 AM
I don't know if I stated in the original post but I am using a wet system(NX) and it came with a "shark nozzle" that goes in the intake elbow. The plate I'm looking at has two bars(one for fuel, one for nitrous), and I thought that might disperse the mixture more evenly.
Are you saying that with your experience the single nozzle was better? I've had the kit since last fall but haven't used it yet....so ANY info is definitely appreciated.
Old Apr 7, 2004 | 06:59 AM
RacinLT1's Avatar
which plate do you have? the Nitrous works plate isnt worth the hassle,i picked up 3/10's by swapping to the nx nozzle/solenoids,using the same jets as NW plate.
i havent used the TNT plate,but it appears to work extremely well from what i have seen.
woops,i just read the top post,is it the tpi NOS plate? if so they work pretty well,but i never did back to back tsting between it and the NX Shark. Also i wasnt sure they fit the LT1 Tbody exactly if it is the tpi plate.
Old Oct 29, 2004 | 10:35 AM
ford's Avatar
Re: using throttle plate with nx wet kit
Just curious how this plate worked out for you, and if there were any fitment issues. Thanks!
Old Oct 29, 2004 | 11:31 AM
chevy1963's Avatar
I'm using the compucar TB plate. It has to brass tube running threw it . One for N2O and the other for fuel
Old Nov 1, 2004 | 08:43 AM
94Zpower's Avatar
The only thing that you have to do is trim the T stat housing a hair, really much at all so dont worry, and now its a PITA to change th T stat because the TB comes out a little further than B4,
kit works good though! not complaints be sides what i mentioned.
alphaauto
Jan 23, 2015 07:42 AM
JamesN1830
Sep 11, 2002 10:57 AM
rje
Sep 9, 2002 12:35 PM
ezcheeze15
Aug 26, 2002 01:28 PM
ezcheeze15
Aug 8, 2002 12:27 AM
