Cam spec question
Old Mar 31, 2004 | 09:36 AM
BBB's Avatar
BBB
Cam spec question
I have the 350hp/ 327ci cam (the old 60s GM cam that was found in 327s like the Nova) in my 350. If I remember right the duration was 224/224.
Does anyone have the specs to this cam? I really need lift and lobe seperation info.
BBB
Old Mar 31, 2004 | 03:24 PM
SS69MAN's Avatar
I wouldn't have a clue...........but the new ones are much better. Trash it.
Old Mar 31, 2004 | 04:32 PM
FiefSS's Avatar
Part Number Type DUR @ .050" Lift C/R LSA Usage
3863151 Hyd. 221/221 .447"/.447" 11.0:1 114 327/350HP L-79
that one? if not just try a websearch.
Old Mar 31, 2004 | 08:31 PM
BBB's Avatar
BBB
Thanks, that sounds about right. I am changing from old crappy smogger heads to ZZ4 heads and I want a cam that can push HP but not emissions. I figure that with 30+ years of tech behind some of the new cam grinds I can get alot more hp and fewer emissions especially with the new heads.
I am looking at a comp XE grind of about 224/230 on a flat tappet/hyd. Off the top of my head it comes in at about .500 lift with a 1.6 rocker. The heads have been redone with springs that can tolerate .600 lift, but I don't need to use all that to max out the airflow.
BBB
Old Apr 1, 2004 | 02:23 AM
Dirt Reynolds's Avatar
Fief posted the correct grind. I heard this cam idling in a rebuilt 350 in a '62 Corvette at a local speed shop last week, and boy it sounds nice. Cool idle, real smooth sounding. I recall back in the 1970s how everyone and their brother would run either that cam or the LT-1 solid-lifter cam in their small block.
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Queens94z28
Nov 20, 2014 06:03 PM
