chevelle header ?
Old Mar 19, 2004 | 01:24 AM
96LT14u2Nv's Avatar
chevelle header ?
i have a 1964 chevelle with a 283 v8. later on this year i am swapping in a LT1 stroker motor(carbed) and i was wondering if whatever headers i buy now, will work with the LT1 too, or if i have to buy headers for a LT1 car. thanks,dj
Old Mar 19, 2004 | 03:34 PM
Jeff H's Avatar
You need to use headers designed for the Chevelle with a small block. I just put some Hooker headers on my 68 Camaro with a 94 LT1 in it. I had to deal with the factory AC stuff so that made it a bigger pain. The difference I noticed was that the LT1 exhaust ports are bigger than the old small block so I ended up grinding out some material in the header flange to gasket match the header ports to the head. Otherwise you'll need some custom headers built with the LT1 flange and the Chevelle small block tubes.
Old Mar 20, 2004 | 12:07 AM
96LT14u2Nv's Avatar
cool. that is what i thought. do u have any pics of yours? i would be very interested in seeing them. is yours carbed or FI?
Old Mar 20, 2004 | 03:54 PM
Damon's Avatar
Buddy of mine with a 72 Chevelle that has a small block (non-LT-1) put a set of Hooker Super Comps on it with 1/3/4" primaries. It's a tight squeeze and the oil dipstick on the driver's side of the block had to be "massaged" but they fit just fine and the large primary diameter will cover up and seal ANY stock exhaust port, including the LT-1's d-port exhaust opening.
Old Mar 22, 2004 | 09:02 PM
Jeff H's Avatar
My 68 Camaro has a 94 fuel injected LT1. I'm still trying to get all the little things ironed out with it. Most of the work was done before I bought the car, but there turned out to be a lot of little issues.
sherwinZ28
11
Aug 15, 2015 05:38 PM
colts0455
Jul 28, 2015 11:28 PM
jbc3
Jul 28, 2015 12:24 PM
Strick
Jul 14, 2015 07:28 AM
