Ac Delete Pulley Install
Old Mar 16, 2004 | 10:47 PM
SHawk670's Avatar
My A/C Compressor has done a fantastic job of being completely locked up and I can't start my car any more because the belt will go no where and when it does start, it's burt belt city. Im wondering how difficult it is to install the A/C Delete Pulley, I just got done replacing my starter to only learn that my ac clutch failed and that was causing my car not to start. Oh well, at least I dont have to worry about a starter going out any time soon.
Old Mar 16, 2004 | 11:00 PM
ledfootz28's Avatar
its not that hard.you ll be glad u did it once u see how much the compressor takes up in space and how heavy it is.3 bolts in the front,the only bitch is theres a bolt in the back i think holding the hose on,i forget its been a while but it wasnt fun.
Old Mar 17, 2004 | 12:24 AM
rock1501's Avatar
I am taking mine out and putting the pulley on this weekend.I was really hoping you were going to say it was cake
Old May 21, 2004 | 07:49 PM
blue's Avatar
a/c compressor
Yes, it is a bastard getting the a/c compressor out. Mine locked up two years ago and I replaced it which was a mistake. I finished my first year of grad school two weeks ago and started on a cam and heads swap last Tuesday. I hadn't planned on doing anything else, but now that I have the a/c stuff out, the crap is not going back in. Our engines are tight enough in there to begin with. a/c delete pulley is $35 on gmpartsdirect.com.
Old May 21, 2004 | 07:50 PM
Spinner's Avatar
Takes 2 secs to put the pulley in, getting the compressor out's the hard part.
Old May 21, 2004 | 09:01 PM
Fuels94TA's Avatar
It's not that hard at all, just that back bolt on the compressor will be a pain. But once you have it out the pulley will slap right in there. Also you will like how easy the plug access will be.
Vinny
Old May 27, 2004 | 12:05 PM
krispy's Avatar
ok I am planning on taking out the A/C comp. (have the pulley here) but from the bottom I see many lines running under the comp. (AIR, A/C, steering)
what ones do I need to remove to get the comp. out, it doesnt look like it will be easy to manuever it outta place
whoever has done it please offer up some info
thanks
Old May 27, 2004 | 01:44 PM
GREGG 97Z's Avatar
I didnt actually think it was that hard to remove the compressor when I installed my A/C delete pulley. I had it out and the pulley installed in about an hour. That back bolt on the compressor was a little tricky to get to.
Old May 27, 2004 | 07:41 PM
krispy's Avatar
do you remember what tubes, bolts, etc you have to take out to get it out, from the looks of it, it doesnt look like i could work it outta there easily
Old May 27, 2004 | 09:19 PM
kyzar24's Avatar
where are yall getting the delete pulley? and how much are they?
Old May 27, 2004 | 09:22 PM
krispy's Avatar
gmpartsdirect.com
bout 42 dollars shipped
part no. 10115875
Old May 27, 2004 | 09:44 PM
rock1501's Avatar
I did my install in about 1 hour.The hardest part was getting the condenser out of the tight area it is in after I had already disconected it.
Old May 28, 2004 | 11:21 AM
krispy's Avatar
what did you remove besides the compressor, no one has any answers on this it seems
Old May 28, 2004 | 11:32 AM
Type_O_Negative_1320's Avatar
Related question...isn't the AC switched on when you flip over to "defog"? Does defog even work without the AC?
The reason I ask is because I'm thinking about taking mine out since the engine is coming out anyways...I just don't want the windows fogging up if I get caught in the rain. If defog works just as well without the AC, then I'll pull it.
Old May 28, 2004 | 11:48 AM
rock1501's Avatar
I just took out the compresser and condenser.
