You guys that DO or KNOW how to CC cylinder heads in here>>>>>
Old Sep 5, 2002 | 05:19 PM
FASTFATBOY's Avatar
Post You guys that DO or KNOW how to CC cylinder heads in here>>>>>
I am CC ing my own heads, I have a plastic burret(0-100 CC)I used alcohol to start and it ruined(melted) a $93 burrett, what other medium(fluid) is used to do this, water will rust the seats, I was using good alcohol and food coloring, but that won't work($93 lesson)any ideas would greatly be appreciated, I am drawing a blank, could not afford a glass burett($160) SO I had to pop for another plastic one.
David
Old Sep 5, 2002 | 06:10 PM
BlackHawk T/A's Avatar
You need a glass burette for the alcohol. If you don't have a glass one, you need to use a different liquid (obviously) .
Solvent tinted with a few drops of dye or automatic transmission fluid work well since they will not rust the metal.
Old Sep 5, 2002 | 06:59 PM
TurboSS's Avatar
Exclamation
I used a plexigalss sheet that I cut to fit the whole head. And put pin holes to fill the CChamber. The plexi was sealed with bearing greese and then bolted on.
Simply use water and food dye. As far as rust goes you have to balance out the CC from piston to piston that means they will see the air gun as well as B-12 carb cleaner again and again. Just clean them up as you go and when you are done.
I have pictures but I'm out of hosting space
TAD
Tad "Notorious" Banzuelo
96 DGGM 14.3 Best 2.0-60ft's Stock LT-1 ODB1 PCM
www.SoCalSS.org - My SS Mods - My Impala SS Diary and Information Page
[This message has been edited by TurboSS (edited September 05, 2002).]
Old Sep 5, 2002 | 08:52 PM
drop top steve's Avatar
I and all I know use transmission fliud, most prefer dexIII
Old Sep 6, 2002 | 06:25 PM
marktisch's Avatar
we use anitfreeze at our shop. The color makes it real easy to see
95' T/a m6
383-ported Lt-1's
Scat crank, eagle rods, custom Fed-Mogul pistons
headers, car back, etc
Ed Wright tuning
to much other stuff
9-inch rear on the way
Owner of
Tischler Competiton Engines-Somerville N.J.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
Elcojoe
Nov 17, 2014 10:27 PM
Red97LT1
Aug 7, 2002 05:45 PM
