t56 experts inside please............
Old Sep 4, 2002 | 07:41 AM
black84 z28's Avatar
Post t56 experts inside please............
i was playing around last night...practicing launches.....went to shift second and it banged loud and now when i shift into second...nothing...everyother gear works perfect...the clutch is a mcloed
shift fork?
Old Sep 4, 2002 | 11:43 AM
Eric Bryant's Avatar
Might be, or you wiped out the synchro hub teeth on the 2nd driven gear. I'm guessing the later, as the shift fork would have to be bent enough to engage first in the neutral position if it wouldn't grab second at all. You should probably take it apart for inspection before you run the broken bits through the rest of the trans and cause bigger problems.
Eric Bryant
'96 Impala SS (LT4 396, T56, "firm" suspension)
'96 GMC K2500 (parts hauler/dune runner)
'92 Roadmaster wagon (winter beater)
'01 Honda Accord LX V6 Coupe (wife's car)
http://www.bryantperformance.com
Bxlt1
Sep 29, 2015 03:18 PM
autoxr166
Sep 25, 2015 04:21 PM
Daluchman1974
Sep 11, 2015 06:12 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
