Battery Drain...
Old Mar 13, 2004 | 01:00 AM
CAJUN-Z's Avatar
From: from the land of Justin Wilson and Huey Long!
Battery Drain...
What I want to know is...is it "urban legend" that if you put a battery on concrete, that it will discharge faster than if you place it on a piece of wood or some other insulator. May not sound too tech, but just wait. I truly don't know the answer. I'm interested in the theory either way. Thanks....
Old Mar 13, 2004 | 08:36 AM
OldSStroker's Avatar
Personally I prefer cherry or some oiled teak, but if they aren't readily available at Home Depot, I just put the battery on the concrete floor.
Seriously, the only reason I see for using a wood underlay is to keep any acid which leaks or drips (from the old style batteries) off the concrete.
Battery trays in cars are usually steel, which is a fair conductor of electricity.
Old Mar 13, 2004 | 09:03 AM
OneFlyn95z28's Avatar
I had one laying on the floor out here for almost a year now. tossed it in the car and she fired right up
Old Mar 13, 2004 | 10:25 AM
Stephen 87 IROC's Avatar
Battery case design about 30-40 years ago may let the battery drain when sitting on the concrete. With the battery construction now that has become an urban myth. I have a bunch of batteries sitting on the floor in my garage. None of them drain down.
Old Mar 14, 2004 | 06:12 AM
CAJUN-Z's Avatar
Originally posted by OldSStroker
...Battery trays in cars are usually steel, which is a fair conductor of electricity.
That was my exact arguement with someone on the subject. Thought I would present it to the "experts"...
My assumptions are probably correct...
Thanks....(although I did think it would get a bit more "technical")
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 01:46 PM
jackpawt883
Sep 10, 2015 08:53 PM
weedog
Aug 15, 2015 08:23 PM
