crankshaft hubs
Old Jul 17, 2002 | 07:33 PM
bowtiepwr's Avatar
Post crankshaft hubs
>I hope this qualifies for this section :
The Callies Dragonslayer crank (3.875") will that connect to the stock LT1 crankshaft hub ? , and what is the difference between the LT1 crankshaft hub (part # 12553250 ) ,
and the LT4 crankshaft hub (part #12550097) ?
Later ...
stay safe
Old Jul 18, 2002 | 09:48 PM
Curt (pres AAMC & ZAA)
Guest
Posts: n/a
Exclamation
Nope, this is more of a LT1 Tech question.
>The Callies Dragonslayer crank (3.875") will that connect to the stock LT1 crankshaft hub?
Yes. You will need to use either the LT1 specific notched key if using a stock damper hub, or you will need a keyed hub.
>what is the difference between the LT1 crankshaft hub (part #12553250), and the LT4 crankshaft hub (part #12550097)?
P/N 12550097 is not a LT4 specific hub. It's shorter to accomidate the crank trigger used on 96-97 LTx OBDII engines. P/N 12553250 is for 93-95 OBDI LT1 engines.
AviatorDave
Dec 19, 2016 06:35 PM
Slayer
Aug 17, 2015 03:55 PM
Boss002
Jul 24, 2015 10:47 AM
mrwz28
Jul 8, 2015 09:11 PM
SergheiS
Jul 5, 2015 03:27 AM
