billet cams and the oil pump drive gear compatible?
Old Jul 11, 2002 | 09:34 PM
jay christopher's Avatar
Post billet cams and the oil pump drive gear compatible?
im in the process of converting to a soild roller cam set up. i want to run a billet cam becuase of the high spring pressures i will be running. i know that gtp and others use them all the time, so my question is, does everybody convert the oil pump drive gear to a brass one? my good freind, an "old school" racer says this is a must with billet cams and a distributer,but we only use it as a oil pump drive in the lt1. so does this make a difference? thanks much for any help, jay
Old Jul 11, 2002 | 11:03 PM
OneFlyn95z28's Avatar
Lightbulb
Jay not really an advanced Question but I have tha answer
GM used Billet cams from the factory so I will say yes The Gear is fine on the Billet
Ellis
Team Captain
Team North West F-Body
www.teamnwfbody.org
[This message has been edited by OneFlyn95z28 (edited July 12, 2002).]
Old Jul 12, 2002 | 06:15 AM
kmook's Avatar
Advanced Tech Moderator
Since this really isnt that adv of a question, like Ellis broght out, i will get this over to LT1 Tech.
Ken Mook - 97' SS #2544
Advanced Tech Posting Guidelines
  • Almost Alive: ?rwhp & ?rwtq Naturally Aspirated on the Stock Bottom End.
  • Stage 3 Pro Performance Heads, Solid Roller 242/248 Cam, Endur-X Lifters,
  • Jet Hot Hooker LTs, True Dual 3" Exhaust with x-pipe, and the list goes on and on...
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Elcojoe
Nov 17, 2014 10:27 PM
