T56 noise
Old Mar 7, 2004 | 12:00 AM
INFERNO's Avatar
T56 noise
First of I did a search and came up with nothing. I have a 1993 Z H/C car with a 95 T56 in it. About 150 miles ago I replaced the clutch with a spec stage 4, New hydraulics (Gm), and new pilot bushing since car was an A4. Last year I replaced the 1st to snd syncro hub assembly due to grinding into gear. The rest of the trans looked great. Here is my problem, When driving the car the trans makes a sound like a bunch of marbles sloshing around in the trans. In my search I heard this is normal? However I revved at a stang in neutral and the trans made a loud a$$ grinding noise like a classic case of can't find them grind them. But I did not grind gears. When I slowly release the clutch in gear there is a faint sound like something rubbing which gets louder when the clutch is fully engaged. I am mostly worried about the the marble sound becuase it sounds like the trans wants to fall apart. I have a pro 5.0 shifter and the trans shifts like brand new so i do not get this problem. Thanks in advance.
Old Mar 7, 2004 | 02:00 AM
jeepz28's Avatar
I just put a spec stage 4 and a pro 5.0 shifter. mine is doing it to it sounds like 2 gears grinding together. first I thought it was my stopers on the shifter that wasn't tight. ThenI though it was just low gear oil but that wasn't it neather. Well anyway I just went out racing tonight and blew apart my rearend thinks to the clutch and the drag tires.
Old Mar 7, 2004 | 10:28 AM
INFERNO's Avatar
I am thinking the rear end is my problem minus the gear grinding. If you move the pinion, the pass side axle will move with no play, the driver's side will move about 15 degrees either way before the axle moves. I think the noise is getting transmitted through the driveshaft.
Bxlt1
Sep 29, 2015 03:18 PM
autoxr166
Sep 25, 2015 04:21 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
rideordie
Sep 7, 2015 08:22 AM
