Installed Pacesetters! One problem..
Old Mar 6, 2004 | 01:29 AM
BigRedZ28's Avatar
Okay so I installed my pacesetters and Y-pipe to the Hooker cat back today! Looks good, sounds alittle loud but not too bad actually! Cool roar when I lay on it! But there is a knocking when I idle like the driveshaft is hitting the floor, and it seems the headers are knocking abit.. it was a tight fit.. is this normal and will it fix itself?
Thanks.
Old Mar 6, 2004 | 03:29 AM
Killaz's Avatar
notch the k member and it will go away
Old Mar 6, 2004 | 03:42 AM
chpmnsws6's Avatar
mine do it also. notch the k-member or lay into it with something inbetween the k-member and the header.... that will bend it out some maybe
Old Mar 6, 2004 | 01:56 PM
BigRedZ28's Avatar
Hmm.... it's only when I am sitting still with it in park does the nocking occur badly. I was told it was my Y-pipe hitting the heat shield. . . and that I could take the heatshield off or just deal with it. Meh. It is pretty loud, I guess thats my fault for not buying Cats. -.-;
Old Mar 6, 2004 | 03:47 PM
jakesnake123957's Avatar
There is 1/8 inch heat shield asbestos stuff,I got it from work,but industrial supply stores should have it.install it between your pipe and heat shield>Jake
Old Mar 6, 2004 | 03:50 PM
chpmnsws6's Avatar
put a wrench or something in there inbetween the shield and the y-pipe then goose it real quick to twist the engine. take the "filler" out and see if it helped any
cats = bad
Old Mar 6, 2004 | 04:41 PM
Mikael's Avatar
A piece of rubber hose between the header and floorboard works great and is much easier.
Nov 18, 2023 07:21 PM
drptop70ss
May 4, 2015 08:22 PM
WildRidez
Mar 27, 2015 08:22 AM
alex5366
Feb 17, 2015 09:07 AM
