DIY Wideband logging
Old Jul 6, 2002 | 08:00 PM
Jay Z28's Avatar
Post DIY Wideband logging
Has anyone successfully built the DIY wideband o2 sensor (www.diy-wb.com) and logged the output along with other engine parameters? I'm toying with the novel idea of using the A/C pressure sensor harness as the wb02 signal line since Datamaster will log this signal and the PCM expects the 0 to 5v range needed for the diywb02. If anyone has done this or has any other input/suggestions, pleas post.
-Jay
94Z A4
Comp Cams 306, GTP Stage 3 heads, other stuff.
<A HREF="http://www.LT1tech.com" TARGET=_blank> www.LT1tech.com </A>
Old Jul 8, 2002 | 12:22 AM
Dr.Mudge's Avatar
Thats the solution others discussed, sounds good to me.
Old Jul 16, 2002 | 11:05 AM
JZ 97 SS 1500's Avatar
Where else has this been discussed??? If the A/C pressure sensor does truly use a 0-5V range, then it should be no problem wiring a WB sensor to it. Let me know what you find out...
Jose
97 SS #1500 T-76 383
88 Supra Turbo CT-26/T04
87 Buick Grand National T-70
Old Jul 20, 2002 | 11:55 PM
pkincy's Avatar
Yes it is a 0-5 mv signal with the 5 mv being provided by the pcm. It is on the same circuit as the TPS switch on my 93.
The only way I know is I melted that sensor on the race car (!AC) and it shorted out and also grounded the TPS sensor!
Perry
Novo
Jun 14, 2016 02:58 AM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
Sep 18, 2015 03:46 PM
tommalcolm
Sep 11, 2015 03:39 PM
