Plastic Squeaking noise?
Old Feb 21, 2004 | 08:02 AM
Bom2000's Avatar
The plastic pieces of my console are squeaking and since my console is falling apart I am getting ready to order a new one but the pieces of my dash still squeak when I hit a bump. I guess the plastic is just rubbing up against each other. How do I stop this from happening? Cause it makes me go nuts sometimes cause it sounds like my car is falling apart.
Old Feb 21, 2004 | 08:26 AM
blackbirdta's Avatar
i dont think it will ever not squeak, but sub frame connectors should make it a little bit more solid
Old Feb 21, 2004 | 11:49 AM
Tair's Avatar
try shoving folded-up black construction paper in between certain panels. I've had success doing this, and you wouldn't even find the paper unless I told you it was there. You'd be surprised....although it may sound like the squeaks are coming from all over, it's usually only 1 or 2 problem areas that you have to fix.
Old Feb 22, 2004 | 10:59 PM
Eliminator's Avatar
I am gonna have to try that once I find the damn mouse in my car it seems to move from one side to another. Squeaks drive me nuts.
Old Feb 23, 2004 | 12:40 PM
Tair's Avatar
Old Feb 26, 2004 | 01:25 PM
fbird95's Avatar
I used peices of interior color felt. THe main and common sqeak is the console to dask sqeak. Check there first.
2QUIK6
Sep 17, 2016 02:31 PM
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
colts0455
13
Aug 7, 2015 09:15 PM
colts0455
Jul 7, 2015 07:19 PM
