ASAP: EGR pipe removal
Old Feb 18, 2004 | 04:15 PM
coogsLS1's Avatar
does this throw a code?
Old Feb 18, 2004 | 04:41 PM
mullettour's Avatar
Unless its tuned out.
Old Feb 18, 2004 | 04:57 PM
coogsLS1's Avatar
I want to remove the pipe but dont want to spend big $$ to get ls1 edit or something...other ideas?
Old Feb 18, 2004 | 05:06 PM
mullettour's Avatar
I dont know, but maybe you could remove the pipe and plug the exhaust and intake manifolds, leaving the egr valve itself in place. I dont know if you did that if it would throw a code or not.
Old Feb 18, 2004 | 05:08 PM
2001NBMZ28's Avatar
Since you have a '98 it might not. I tried removing the air pump fuse on mine and immediately got a P0412 code. Try removing the fuse and see what happens - you can always stick it back in there.
Old Feb 18, 2004 | 05:16 PM
coogsLS1's Avatar
ok ill do that, when a code is thrown, you can tell be setting the SES light right?
Old Feb 18, 2004 | 05:28 PM
mullettour's Avatar
2001nbmz28-egr and the air pump are 2 different systems. If you have a 2001 you dont have an egr valve.
coog-you would know if you got a code because your ses light would come on.
Old Feb 18, 2004 | 10:22 PM
2001NBMZ28's Avatar
Opps, my bad - I was thinking !AIR.
HectorM52
Jul 30, 2017 11:46 AM
drptop70ss
May 4, 2015 08:22 PM
97SSdude
Dec 31, 2014 07:43 PM
thenewkid
Nov 18, 2014 12:57 PM
