Two Exaust Pipes?
Old Feb 11, 2004 | 07:15 PM
Vega's Avatar
Question Two Exaust Pipes?
I've notice all the V6 Camaros 1998 and Up all have just one exhaust pipe. I have two exhaust pipes; is there something special about my Car or what?
Edit: I have 1999 V6 3800
Old Feb 11, 2004 | 09:57 PM
99blackSS's Avatar
Check the inside of your drivers door. In the door jam there is going to be a list of RPOs if one of them is Y87 then it came that way from the factory. If it doesn't say Y87, a previous owner installed it. Also, if it does have the Y87 option your steering ratio is the same as a Z28s.
Old Feb 11, 2004 | 10:02 PM
MustangEater82's Avatar
Also if you have a Y87 car you have LSD, and 3.42 gears... its a performance package... kinda like an SS but for v6s
Old Feb 11, 2004 | 11:00 PM
Need4Camaro's Avatar
Interesting, does the Y87 have any HP difference from the regular V6? and I've seen 98+ V6 Firebirds with dual exhaust, did they have a performance package simular to the V6 Camaro's?
Is a steering ratio simular to the Z28's good for V6's or bad?... I drove my dad's Z and as far as steering goes, it feels like a truck.
Give us a shout Vaga if you got the Y87 package.
Old Feb 11, 2004 | 11:49 PM
Vega's Avatar
Yup! It says Y87. Now does my car have more HP then a standard V6 Camaro?
Old Feb 12, 2004 | 12:03 AM
ImportKILLER's Avatar
No...but that doesn't mean other Camaro owners wouldn't like to have your car!
Old Feb 12, 2004 | 12:11 AM
99blackSS's Avatar
No, but the better gears it has will give it a edge.
As for the Z28 steering ratio, that means you don't have to turn the steering wheel as much as a normal V6 Camaro to turn.
Old Feb 12, 2004 | 08:51 AM
Vega's Avatar
oh yes here it is:
"An optional Performance Handling Package puts dual exhaust, tighter steering and a limited-slip differential on the V6 Camaro."
http://www.autofan.com/january99/2/index.asp
Old Feb 13, 2004 | 05:42 PM
94ZRiCeKiLr's Avatar
"dual exhaust" ....heh heh they embellish that one a little huh....
G-BODYT56
Jan 14, 2022 11:14 PM
n2oblkz
Oct 12, 2015 01:53 AM
football4life
Oct 4, 2015 07:48 AM
Ks0209
Oct 1, 2015 07:32 AM
greenzee28
Sep 25, 2015 04:29 PM
