How to get to bolt off thermostat of 3.4??
I am trying to figure out the fastest way to get the thermostat housing bolts off my 95 3.4. My Z is so much easier to get to.
What do you all use to get the bolt that is closest to the driver side off?? That is a very tight space.
Thanks!
Thanks!
I use a wobbly and a socket works fine for me! Try coming at it from both sides and see which one works best for you... I even have used a wobbly headed ratchet and just the socket... Good luck and i hope this helped a bit
Thanks for you fast response!
