Goodyear GS-CS slicks?
Old Jul 3, 2002 | 04:50 PM
BigRich's Avatar
Post Goodyear GS-CS slicks?
also, i got these slightly used Goodyear GS-CS racing tires. 255 50 16 for autox.
anybody ever use these? i don't know how good they are since they are my first racing tire. i ran them 38 lbs front, 34 lbs rear and i could still feel the sidewall flexing. more pressure?
Old Jul 9, 2002 | 10:48 PM
99HOSS's Avatar
I don't Auto-X, but attend open track sessions and the last one I ran the GS-CS tires. Usually I run Hoosiers, but was given a set to try.
I run 36 front and 34 rear (cold) for road racing.
Chalk mark your sidewall up onto the tread and see what it looks like after a session. That will tell you if you're using all, most or some of your tire.
Old Jul 10, 2002 | 04:56 PM
BigRich's Avatar
thanks. went to autox last week and ran 42 psi all around. the fronts rose to 45 and i let out a little in the back to 40.
also used some chalk. no rollover. those pressures are really high, but with the lower speed sharp turns at autox, i noticed much less sidewall flex than when they were at 34-35.
then i rode in my friend's 99 SS with 275 Hoosiers all around for a fun run. he definitely has more grip. i need to go to 275s when these are done.
Mar 13, 2016 03:37 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
Chris`s85Z28
3rd Gen / L98 Engine Tech
15
Sep 5, 2002 01:54 PM
cdmelcher
Jul 18, 2002 06:28 PM
VVaKeMaN
New England Area
Jul 5, 2002 03:56 PM
