Rear sway bar end links with lowering springs
Old Jun 24, 2002 | 09:13 AM
lylehowell's Avatar
Post Rear sway bar end links with lowering springs
I would like to know how to adjust for 1 1/2" lowering springs. My stock sway bar end links looked old and I replaced them with Energy Suspension type, I used part number 9-8120g and are shorter by 1 1/4" or so, now the car rides high in the back.
1995 Pontiac Firebird
Old Jun 24, 2002 | 10:59 AM
Norm Peterson's Avatar
I'm not quite sure what your question really is. I'm guessing that you also just swapped in the new springs and either they haven't had time to settle or they didn't get indexed correctly.
Swapping to the shorter endlinks for the rear bar has no effect on the rear ride height. Going shorter with their replacement was the correct thing to do.
Norm
1979 Malibu, 355, 5 speed, cornering tweaks, some other stuff
2001 20th Anniversary Maxima, 5 speed
[This message has been edited by Norm Peterson (edited June 24, 2002).]
Old Jun 24, 2002 | 04:41 PM
Dr.Mudge's Avatar
The car is suspended by the springs, not by end links.
Old Jun 29, 2002 | 06:54 PM
v7guy's Avatar
so your suppose to shorten the endliks when you lower the car as well? didn't know this? Where can I get em?
There's one more thing on the to do list
Old Jun 29, 2002 | 11:00 PM
lylehowell's Avatar
<font face="Verdana, Arial" size="2">Originally posted by nov194:
</font>
I found 2.250 spacers with 6.500 3/8" bolts to work just right for my lowered car.
1995 Pontiac Firebird Formula 57,000 miles
Old Jul 1, 2002 | 07:15 AM
. . . Where can I get em? . . .</font>
On the cheap, you can simply cut down your existing sleeves and re-use the bushings. But I'd recommend replacing the bolts.
Norm
87Aerocoupe
Jan 10, 2015 07:27 PM
ModdedNerd
Dec 25, 2014 05:51 PM
siguy
Nov 27, 2014 10:07 AM
thenewkid
Nov 27, 2014 09:41 AM
IgorT.455/406
Feb 1, 2005 06:18 AM
