Fault in Quad Driver Module
Old Jan 20, 2004 | 06:19 PM
Decap92RS's Avatar
I ran my little diagnostic test on my 93 Z, and it came back as a Fault in Quad Driver Module.
OK, thanks for that bit......but does anyone know what a quad driver module is? What do i do to fix it? ANy info is greatly appreciated :-)
PS: Yes I know that my car isn't a third gen....its the only year fourth gen that uses the same method of diagnosing.
Old Jan 21, 2004 | 06:07 AM
greezemonkey's Avatar
The quad driver is internal to your computer, It`s job is basically the same as a relay. The driver however never see`s a load like a true relay. I am unsure of how many and what devices your computer quad controls but hence the name "quad" its capable of completing 4 circuts. Most cars that I have repaired with this problem usaually utilize all four drivers. You will need a "real" scanner to find what device is acting up, some cars list codes as quad driver "a" fault or "b" and so on, in this case you can trace it down yourself. I can fax or upload a schematic of the possibilities that can make that code appear, if you like. Most times a small selenoid or switch is the culrpret.. a/c compressor, egr sel., purge sel., fan switch and so on..Not saying it cant happen but I never seen this problem repaired by changing out the ecm.
Old Sep 17, 2004 | 05:14 PM
Decap92RS's Avatar
Re: Fault in Quad Driver Module
i had gone all this time without even messing with it, and the light went off, and hasnt come back on, I knwo the light still works, now Im worried, I doubt it fixxed itself....
Old Oct 13, 2004 | 10:50 AM
93redbird's Avatar
I went through water and all the sudden I am getting a quad driver module A causing a problem. Do you think this could be due to a solenoid?
Tim
timmy39120
May 8, 2015 11:41 AM
markzzzz
May 8, 2015 09:21 AM
94Z28LS1toLT1
Apr 30, 2015 05:19 PM
dluna333
15
Mar 13, 2015 12:30 PM
skittlez87
Dec 29, 2014 03:24 PM
