New England Area For members in Connecticut, Maine, Massachusetts, New Hampshire, Rhode Island, and Vermont.
Lean or Rich?
Old Jun 16, 2002 | 09:11 AM
BlackLS1Z's Avatar
Post Lean or Rich?
What are the possible ways of finding out if my car is running lean or rich?
Colin
98 Z28
Old Jun 16, 2002 | 10:42 AM
sleeperZ96BT's Avatar
off the top of my head autotap or another scan tool, or get it on deans dyno (plug for ya dean!) FWIW, why are you asking the question?
brian
Old Jun 16, 2002 | 01:20 PM
BlackLS1Z's Avatar
I used a-tap and its showing my O2's at .025 @ WOT. This a far cry from the optimum .9XX (from what I've been told). Its giving me an SES light P0131, P0137, P0151, P0157...all low voltages for the O2's. The O2's are brand spankin' new along with the fuel filter. I'm guessing its running way lean. I'm not sure what to look at from this point. The car is down on power and its very very frustrating seeing that damn SES light. Any help would be much appreciated! Thanks
Colin
1998 Z28
Old Jun 16, 2002 | 03:35 PM
are you stock, mods, what? that would help get an accurate answer.
brian
Old Jun 16, 2002 | 05:43 PM
BlackLS1Z's Avatar
The only mods I have are a lid and exhaust. Basically a stock 98 Z28 with close to 80k on it. In some desperate need of guidence Thanks!
Colin
98 Z28
Old Jun 16, 2002 | 09:28 PM
Slowhawk's Avatar
You might have a blown fuse or bad ground.
01Firehawk pewter M6
TNT wet,FLP's,Corsa,MTI clear lid,Tbyrne LCA's PH,KVR cross drilled.TR 220 Cam and other stuff.
12.84 at 108 1.93 60' with stock tires before Cam
370hp/370tq
Old Jun 17, 2002 | 04:57 AM
BlackLS1Z's Avatar
Bad Ground...Oh no .....that sounds like something that will be hard to track down...hope its not that. I'll take a look at the fuses later today. Thanks!
Colin
Old Jun 17, 2002 | 09:06 AM
Slowhawk's Avatar
I've also seen the problem you described after the installation of a SLP fan switch.(They wired some wrong)
Also your plugs and wires could be shot.
Old Jun 18, 2002 | 05:59 PM
BlackLS1Z's Avatar
I think I fixed the problem! I took a look at the MAF and the little wires were coated with this black stuff so clean them off gently. Now when I hit the throttle the O2's are reading between .89 and .91 and I haven't received an SES light yet! Thanks for all the help...much appreciated.
Colin
98 Z28
Old Jun 19, 2002 | 07:08 AM
TTA89's Avatar
Those wires are Ultra sensitive. Usually if you so much as touch them, it will miscalibrate the MAF.
-Mike
1989 Turbo Trans-Am
|11.25@121|11s For $1000 Bucks|HomePage
1998 Trans-Am LS1 6-Speed
|13.10@106|Mods|296HP/319TQ Stock
Old Jun 19, 2002 | 04:54 PM
BlackLS1Z's Avatar
I used some electronics cleaner and q-tips to clean it. I had not choice really....you should have seen the crap on those wires. I didn't realize how bad it was until this morning....she goes real nice now.
Colin
PopoFormula
Oct 12, 2015 04:19 PM
drt
Sep 27, 2015 04:39 PM
HAWG
Sep 25, 2015 11:41 AM
marlar98
Sep 19, 2015 07:53 AM
