eagle stroker and small base circle.
Old Jan 10, 2004 | 05:59 AM
Kyle@CSS's Avatar
I built a LT1 383. The guy that did my machine work said I would need a small base circle cam. I had comp cam build on a custom small base circle cam. Its a nice cam. But I decided to put a regular small block in my Z28. Its already got a cage in it. And Im making it a pure race car. I also have a 1994 yellow formula. The engine started knocking. Im going to put my stroker engine in it. Im going to downsize on the heads and cam. I m wanting it to be alot more streetable. Can I just get a off the shelf cam? Or does it need to be on a small base circle also. Its the 4340 crank 3.75 stroke, and h-beam 5.7 rods. Im also going to need another set of heads. These heads arent what Im wanting to use everyday. But I need to know about this cam asap. So I can get this done. Im leaving my wife with out a ride seince we only have the tahoe running.
Old Jan 10, 2004 | 09:15 AM
jay g's Avatar
i have the forged eagle 383 crank, eagle h beams, and a standard cc 503 cam with no clearance problems with the cam
Old Feb 5, 2004 | 07:00 PM
Kyle@CSS's Avatar
Anyone else.
Old Feb 5, 2004 | 11:28 PM
SStrokerAce's Avatar
With MOST 383's you don't need a small base circle cam.
At least on a Eagle H Beam setup.
Bret
Old Feb 5, 2004 | 11:41 PM
racer7088's Avatar
Arrow
Depending on the rods you have you may or may not need a small base circle cam and/or you will also need to clearance your rods.
Old Feb 6, 2004 | 06:13 AM
Kyle@CSS's Avatar
I already have the engine in the car. I have a cam with asmall base circle now. Im wanting to change it. I would hate to buy another cam that I cant use.
Old Feb 6, 2004 | 07:31 AM
bkrepindy's Avatar
I have an Eagle rotating assembly: 4340 Crank and 6" Rods. I used a standard base circle cam (Crane) with no problems.
Old Feb 6, 2004 | 12:22 PM
You don't need to change it, you can still use that one but a small base circle cam is NOT required.
Bret
Old Feb 6, 2004 | 05:52 PM
Kyle@CSS's Avatar
My cam is on a 110. Comp cam built it that way. Im spraying 150 or more. SO I need to change it.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Drtryder
Apr 22, 2015 04:17 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
Catmaigne
Dec 25, 2014 12:16 PM
