Part # for 224/224 cam
Old Jan 7, 2004 | 11:51 AM
Gripenfelter's Avatar
I need a part # for this Comp Cams cam:
Comp Cams Xtreme RPM grind
.563/.563 Dur@.050: 224/224 LSA: 112
Old Jan 7, 2004 | 04:22 PM
Gold Z's Avatar
That is the TR224 cam. You can find specs, pricing, and even dyno sheets for the cam at http://www.thunderracing.com/. That is probably the best all around cam you can put in a LS1. It's been the cam that all others have been compared to. Excellent choice!
Old Jan 8, 2004 | 10:57 AM
So this cam is only available only through Thunder?
Old Jan 8, 2004 | 10:24 PM
Gold Z's Avatar
No. Others have copied it or very slightly altered the specs. It is a Comp grind so you could also order it through them. I personally find it better to buy from the vendors who support this website. Customer service counts a bunch and Thunder Racing is one of the most respected companies around that specialize in LS1s.
Old Jan 11, 2004 | 06:47 AM
Demon SS's Avatar
The Comp Cams lobes numbers are 3715 for a 224 duration at .568 lift so you would ask for that lobe number on the intake and the exhaust and pick your LSA and I usually set our cams up at +2 advance.
The difference between .563 and .568 lift is minimal.
oldschool
Feb 9, 2016 09:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
