working with vinyl
Old Dec 29, 2003 | 01:00 AM
joshp14's Avatar
working with vinyl
Wasn't sure where to put this so I'll ask here.
I have a few questions on working with vinyl.
How would I form vinyl over lettering like this w/o getting wrinkles? How should I make the letters...and how should I make the vinyl stick?
I want to make a box like this for amp display.
http://home.austin.rr.com/linkless/large/DSC00992.JPG
But instead of having the WS7 emblem there, I would rather have the 3D effect lettering there....something like this....but obviously smaller.
http://www.subthump.com/images/subthumpboxes/ta02.jpg
All help is appreciated.
Josh
Old Dec 29, 2003 | 06:14 AM
LS1 RULZ's Avatar
I use 3M adhesive spray (High Strength 90, NOT the Super 77) to attach the vinyl to the guitar speaker cabinets I build. Here's a 4x12 cabinet I just built and wrapped in vinyl.
http://pic5.picturetrail.com/VOL83/5...4/39611980.jpg
To do lettering would require some good contact cement and a heat gun to help form the vinyl around the letters.
Old Dec 29, 2003 | 11:35 AM
joshp14's Avatar
So would I need to strecth the vinyl at all? or just adhere it down? Also, on the lettering, would I apply the cement to the back of the vinyl first, and then use the heat gun, and then press it down? or would i even need cement on the letters?
Old Dec 29, 2003 | 11:58 AM
LS1 RULZ's Avatar
The only stretching you need to do, if any, is when going around corners and stuff.
You put contact cement on both surfaces. Wait a while for it to tack and then press the pieces together.
Old Dec 29, 2003 | 01:36 PM
joshp14's Avatar
How do you keep it from wrinkling/creasing when going around corners and such?
Old Dec 29, 2003 | 01:47 PM
LS1 RULZ's Avatar
Contact cement. Once the two surfaces are bonded together they aren't going anywhere.
Old Dec 29, 2003 | 06:16 PM
joshp14's Avatar
Any ideas on what I can use for the letters?
Old Dec 31, 2003 | 03:22 PM
notstock4long's Avatar
Use the heat gun to keep it from wrinkling. If you use the heat gun, you can stretch it, therefore keeping it from bundling up and wrinkling.
Old Dec 31, 2003 | 06:41 PM
megabass's Avatar
Also, you don't want to stretch it too much, you'll skew the grain and it will look bad. That's why I don't mess with the stretchy kind of vinyl.
Old Dec 31, 2003 | 08:32 PM
joshp14's Avatar
Thanks guys. I will keep that in mind. I just did a practice for the lettering. I cut out the letters with cardboard and then glued the cardboard to another piece of cardboard. It turned out really well. Hopefully I can get the same turnout when I do it again.
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
phoenix95
Jan 8, 2015 02:44 PM
Dec 4, 2014 11:56 AM
vinnyxgunz
Aug 28, 2002 09:41 PM
Chrisdude
Jul 25, 2002 05:54 PM
