LED Lights vs. Bulbs for instrument Panel
I was wondering if anyone here with a 1990-1992 Camaro has tried installing the LED lights rather than the regular bulbs in your STOCK instrument panel?
I believe it would look similar to http://images.cardomain.com/member_i...983_7_full.jpg (yes, 4th gen, not a 3rd)
These LED's are definately NOT CHEAP and think it would be better to hear first hand who has already done this.
Anyone here have pictures of the end results of the LED's in a STOCK instrument panel?
Thanks
Thanks
do a search over on http://www.thirdgen.org/ , I seem to remember several guys have done it and posted pics
Guest
Posts: n/a
Yes I will be doing this conversion soon (already did in my truck).
The only problem with going to LEDs (or any other bulb for that matter) is that the cluster overlay is yellow. Put blue lights behind that and you will get a pretty little green (this is discussed at thirdgen.org).
I still havnt figured it out... but for some reason, GM was yellow-happy in the early 90s. All the other 3rd gens were left white/clear.
Guest
Posts: n/a
Originally posted by camarosource
Where is the yellow? Is it the overlay itself? or a removable yellow stripe inside the instrument panel?
But in the other messages at thirdgen.org they mention some store, where they sell new overlays... so im assuming the yellow is actually built into the overlay.
Not sure yet.
Not sure yet.
Guest
Posts: n/a
I would rather have a complete Reverse EL glo guage but they don't make them for my Camaro (1992 Camaro Z28 with 240km/140mph guages.) :-(
Im in the same 140mph guage boat as you...
Guest
Posts: n/a
Heres a couple of posts on the subject:
http://www.thirdgen.org/techbb2/show...hreadid=215320
http://www.thirdgen.org/techbb2/show...hreadid=215510
Somewhere in there on one of the posts... you can download the "designs" off his webpage. How would this work? Do you just print it off on some sort of special paper? hah
What do those guages look like?
http://www.procarparts.com/store-det...%2D20XX%2DRVGX
Post #2: Of course I know of the 2nd post, notice the poster? ;-)
Guest
Posts: n/a
Maybe it was this one:
http://www.thirdgen.org/techbb2/show...hreadid=213503
My POS computer isnt linking to sites correctly. Plus I have people IMing me like CRAZY RIGHT NOW. (10+ people).
So what about the response of MrDude_1? What are you supposed to do with those designs?
Re: LED Lights vs. Bulbs for instrument Panel
Thanks
Thanks
Guest
Posts: n/a
Hey camarosource, I decided Im going to go ahead and go out on my own (scan my own stuff).
I have access to a ton of special scanners and printers, so Im sure I can get it all to work.
Main reason is because I cant find the 140mph (or 145, whatever it is) designs.
You can clearly see the difference in the two:
ftp://68.1.231.79/New%20Folder/140.jpeg
ftp://68.1.231.79/New%20Folder/110.jpeg
But I guess I can just put all the overlays on transparency?
I still have the biggest problem because unlike you, I have the 240KM/140MPH (Canadian) rather the US 140MPH/240KM.
Guest
Posts: n/a
I still think, though, if you just scan the images to your computer (as black and white, or greyscale) and then edit the colors as needed, then just print off on a thicker type of transparency, you will be just fine...
Ill be doing this soon and ill take pics as I go.
