Are there any valves I can buy and pop right in w/o any machining at all??
I've searched but still confussed about some things. People have been saying that ths biggest valves to put into a stock Lt1 head is 2.02/1.6 on stock seats. That that mean no machining at all, just install the valves and that's it? I have a set of 2.08/1.6 AFR valves just sitting in my room. Can I install that without bringing the heads to get valve jobs and what not? I know I won't use them to its potential but will it flow less than stock valves since there so big?
Anytime you install valves you should do a valve job, even if they are simply stock replacements. If you tried to install valves of a different size you would quickly damage the heads and then the valves.
Rich Krause
Rich Krause
Originally posted by ChewyChevy
I think it depends on the quality of the valve job..amount of angles..proficiency. Average of 200 bucks or so for just the valve job?
dluna333
15
Mar 13, 2015 12:30 PM
